Controlling buzzers on secondary core of esp32-s3-wroom-1
I have a custom made PCB with 3 buzzers connected to an esp32-s3-wroom-1. I set up a routine on core 0 that takes the wanted frequencies and applies them to the buzzers but no sound comes out. When I use the tone function inside setup it works, but I want to be able to write to all 3 buzzers at the same time. I also tried using the LEDC library but the IDE keeps giving me the following error:
error: 'ledcSetup' was not declared in this scope
10 | ledcSetup(LEDC_CHANNEL, 50, LEDC_RESOLUTION);
and:
12 | ledcAttachPin(LEDC_PIN, LEDC_CHANNEL);
| ledcAttach
code with LEDc:
#include <Arduino.h>
// Define LEDC channel, GPIO pin, and resolution
#define LEDC_CHANNEL     0
#define LEDC_PIN         46
#define LEDC_RESOLUTION  10  // 10-bit resolution (0–1023)
    // Initialize LEDC channel with 50Hz frequency and 10-bit resolution
    // Attach the LEDC channel to the GPIO pin
    // Calculate duty values for 10-bit resolution
    int maxDuty = (1 << LEDC_RESOLUTION) - 1;
    ledcWrite(LEDC_CHANNEL, maxDuty * 0.075);   // 7.5% duty cycle
    ledcWrite(LEDC_CHANNEL, maxDuty * 0.0875);  // 8.75% duty cycle
    ledcWrite(LEDC_CHANNEL, maxDuty * 0.0625);  // 6.25%
code with custom function on core 0:
#include <SPI.h>
#include <SoftSPIB.h>
#define MAX_LEN 64
SoftSPIB spi(17, 18, 35);
#define PWM_PIN 46
int freq1 = 440;
int freq2 = 0;
int freq3 = 0;
bool buzzer1 = 0;
void buzzerHandle(void* parameter) {
  long lastTime = 0;   // Store the last time for frequency checking
  uint8_t buzzer1 = 0; // State of buzzer1 (0 = off, 1 = on)
  for (;;) {
    long time = micros();  // Get current time in microseconds
    // Check if frequency for buzzer1 is greater than 0
    if (freq1 > 0) {
      // Calculate period in microseconds for the given frequency
      long period = 1000000L / freq1;  // 1 second / frequency = period in microseconds
      // Toggle buzzer state when the period is reached
      if ((time - lastTime) >= (period / 2)) {  // Toggle every half period
        buzzer1 = !buzzer1;  // Toggle buzzer state (0 -> 1 or 1 -> 0)
        lastTime = time;     // Update last time
    Serial.println(buzzer1);
    // Output the signal to pin 46
    digitalWrite(PWM_PIN, buzzer1 == 0 ? LOW : HIGH);
    // You can adjust the delay here if needed, but keeping it minimal to avoid time drift
    delayMicroseconds(10);  // Short delay to prevent excessive CPU usage
  spi.begin();
  pinMode(46, OUTPUT);
  tone(46, 440, 3000);
  TaskHandle_t buzzerTask;
  xTaskCreatePinnedToCore(
    buzzerHandle,   /* Function to implement the task */
    "handleBuzzer", /* Name of the task */
    10000,          /* Stack size in words */
    NULL,           /* Task input parameter */
    0,              /* Priority of the task */
    &buzzerTask,    /* Task handle. */
    0);             /* Core where the task should run */
  char buffer[MAX_LEN + 1];  // +1 for null terminator
  for (int i = 0; i < MAX_LEN; i++) {
    buffer[i] = spi.transfer(0x00);  // Read one byte by sending 0x00
  if (buffer == "B1 440Hz") {
is there a problem where the 2nd core is not able to access the ports or is the code simply wrong? I have looked on multiple websites for help but I cannot find anything that can help me understand the LEDC library (it would be a better variant than using the other core). Does anyone have any experience with it?
I am 90% sure that is a Boards 3 issue. Check the Migration document for led references, or just roll back the Espressif esp32 board entry to 2.0.17 and try the compile again. NOTE that this will lock you into old code and force manual updates. It is better to rewrite the ledcattach using the new 3.x API, which is also tersely documented in the Migration doc.
i managed to find a post from someone with the same problem where there was an answer to the question
post: Making tones with ESP32 PWM- poorly documented - #12
I told you the answer. This is a well known issue. Espressif made breaking changes, either revert to the 2.0.17 boards that uses the ledcSetup or chage your code to use the new 3.x function. Here is screen grab. Doc is at https://docs.espressif.com/projects/arduino-esp32/en/latest/migration_guides/2.x_to_3.0.html
