Controlling devices with a TV Remote
I've set up a recycled IR sensor from an old VCR with my Arduino. I heavily modified a sketch and used the library from http://www.arcfn.com/2009/08/multi-protocol-infrared-remote-library.html to display number values from keypresses, documented a value for each key, and used a switch / case statement to activate different pins based on keypresses.
I used a samsung remote, but this will work with any TV remote, and could work with any device that can output IR at 38kHz, AFAIK.
Use a SSR instead of the LED to control line voltage ac devices, and a MOSFET or BJT for DC devices. A neat adaptation would be changing a variable with the vol up/down for a thermostat or Light dimming. The TV channel buttons would work for this as well. Better yet, if one could select a device with the number pad, and use a button to on / off, and the volume to change levels. My simple code does not implement that. I'd be interested it seeing it done though.
Full details, including video at Arduino Your Home & Environment: Arduino IR Receiver - Part 2
 * IRremote: IRrecvDump - dump details of IR codes with IRrecv
 * An IR detector/demodulator must be connected to the input RECV_PIN.
 * Version 0.1 July, 2009
 * Copyright 2009 Ken Shirriff
 * http://arcfn.com
 * JVC and Panasonic protocol added by Kristian Lauszus (Thanks to zenwheel and other people at the original blog post)
 * Heavily modified by Steve Spence, http://arduinotronics.blogspot.com
#include
int RECV_PIN = 19;
int reversePin = 4;                 // LED connected to digital pin 4
int forwardPin = 5;                 // LED connected to digital pin 5
int playPin = 6;                 // LED connected to digital pin 6
int pausePin = 7;                 // LED connected to digital pin 7
IRrecv irrecv(RECV_PIN);
decode_results results;
  irrecv.enableIRIn(); // Start the receiver
  pinMode(reversePin, OUTPUT);      // sets the digital pin as output
  pinMode(forwardPin, OUTPUT);      // sets the digital pin as output
  pinMode(playPin, OUTPUT);      // sets the digital pin as output
  pinMode(pausePin, OUTPUT);      // sets the digital pin as output
  if (irrecv.decode(&results)) {
    long int decCode = results.value;
    Serial.println(decCode);
    switch (results.value) {
      case 1431986946:
        Serial.println("Forward");
        digitalWrite(forwardPin, HIGH);   // sets the LED on
      case -11780576:
        Serial.println("Reverse");
        digitalWrite(reversePin, HIGH);   // sets the LED on
      case -873913272:
        Serial.println("Play");
        digitalWrite(playPin, HIGH);   // sets the LED on
      case -1025287420:
        Serial.println("Pause");
        digitalWrite(pausePin, HIGH);   // sets the LED on
      case 1791365666:
        Serial.println("Stop");
        digitalWrite(forwardPin, LOW);   // sets the LED off
        digitalWrite(reversePin, LOW);   // sets the LED off
        digitalWrite(playPin, LOW);   // sets the LED off
        digitalWrite(pausePin, LOW);   // sets the LED off
      default:
        Serial.println("Waiting ...");
    irrecv.resume(); // Receive the next value
