Controlling different servos simultaneously ?
hello alltogether,
I’m bloody new to arduino & co, unfortunately lost and might need some help
with synchronising some servos.
Just shortly to understand my project:
I want to create a movable “water-tap” controlled by 3 servos.
See: http://www.freshform.de/download/Mario.mov
To get some kind of realistic behaviour/gestures, the servos need to
work all simultaneously! So I could e.g. create a circular movement out of
back/forth and left/right.
With my code so far, the functions only go one after the other, which defentitely
doesn’t work for my purpose.
//int pulse = 0;        // Amount to pulse the servo
//int end = 0;
//int act =0;
//int counter=0;
/*int refreshTime = 20; // the time needed in between pulses
unsigned long lastPulse = 0;*/
//int analogValue = 0;  // the value returned from the analog sensor
//int analogPin = 0;    // the analog pin that the sensor's on
// minPulse = links ; maxPulse = rechts
//servo1
int servoPin1 = 2;     // Control pin for servo motor
int minPulse1 = 850;   // Minimum servo position
int maxPulse1 = 1400;  // Maximum servo position
//servo2
int servoPin2 = 3;     // Control pin for servo motor
int minPulse2 = 500;   // Minimum servo position
int maxPulse2 = 2400;  // Maximum servo position
//servo3
int servoPin3 = 4;     // Control pin for servo motor
int minPulse3 = 400;   // Minimum servo position
int maxPulse3 = 2400;  // Maximum servo position
  pinMode(servoPin1, OUTPUT);  // Set servo pin as an output pin
  pinMode(servoPin2, OUTPUT);  // Set servo pin as an output pin
  // pinMode(potPin, INPUT);  // Set servo pin as an output pin
//pulse = 1500;           // Set the motor position value to the minimum
  moveServo(servoPin1, 850, 1400,1,1,2,2);
  moveServo(servoPin2, 500, 2400,3,3,5,5);
void moveServo(int servoPin, int minPulse, int maxPulse, int v1, int v2, int d1, int d2) {
for (int i=minPulse; i<maxPulse; i = i + v1) {
// count up
  digitalWrite(servoPin, HIGH);   // Turn the motor on
  delayMicroseconds(i);       // Length of the pulse sets the motor position
  digitalWrite(servoPin, LOW);    // Turn the motor off
  delay(d1);
  for (int i=maxPulse; i>minPulse; i = i - v2) {
// count down
  delay(d2);
void moveServo1() {
for (int i=minPulse; i<maxPulse; i = i + 1) {
// count up
  delay(2);
  for (int i=maxPulse; i>minPulse; i = i - 1) {
// count down
  delay(2);
void moveServo2() {
for (int i=minPulse; i<maxPulse; i = i + 3) {
// count up
  delay(5);
  for (int i=maxPulse; i>minPulse; i = i - 3) {
// count down
  delay(5);
Does anyone has an idea, understandable for a beginner like me?
tx for all thinking
joto
