Hey all, I currently do not own any Arduinos, however I do have an older Raspberry Pi Model B (512mb version in case that helps)
I installed two 80mm fans in a guitar tube amp of mine, as it was getting extremely hot without them, to a point in which it made me uncomfortable. The fans are currently hooked up to an old PC power supply, running 24/7, which is a bit of a waste...
Now, I would like to automate the fans in such a way that, when I turn the amplifier on, the fans turn on as well, but when the amp is turned off, the fans stay on for about a half an hour, then automatically shut off. Is this possible? If yes, what will I need?
If necessary, I can post a link to the schematics for the amp, although I'm trying to keep from modifying the amp as much as possible.
Would you plan to have the arduino powered continuosly/separate from the amp? Or are you going for a complete automated shutdown after say a half hour delay?
