Problem:
I have an HDMI switch that is controllable via RS232
Scenario 1:
Setup: PC connected to HDMI switch using USB -> serial adapter
Test: Opening PuTTY on COM port and sending command "sw i01" from my PC
Results: HDMI switch input changes to port 1 [Good]
Scenario 2:
Setup: Arduino UART port connected to TTL->RS232 adapter connected to serial->USB adapter connected to PC with PuTTY program open on COM port
Test: Sending command "sw i01" from Arduino to PC using code below
Results: "sw i01" prints repeatedly on the Putty terminal [Good]
Scenario 3:
Setup: Arduino UART port connected to TTL->RS232 adapter connected to HDMI switch serial port
Test: Sending "sw i01" from Arduino repeatedly to HDMI switch using code below
Results: HDMI port does not switch from port2 to port1 [Bad]
Hardware:
Intel Galileo Gen 2
SparkFunRS232/TTL Shifter connected to Galileo UART
HDMI switch is IOGear GHSW8141
Code:
[Note: Galileo Gen 2 requires Serial1 for UART communication]
Serial1.begin(19200);
Serial1.print("sw i01");
Serial1.write(13); // CR
Serial1.write(10); // LF
Question:
It seems like Scenario 1 and 2 confirm that the Arduino->HDMI switch communication should work, but it doesn't. Am I missing something regarding physical connectivity? Does manually typing "sw i01" in PuTTY send different commands than I have in the Arduino code?
