Controlling HID ballast with Arduino
Hi guys,
I recently purchased a HID grow lamp and ballast however im looking to use an Arduino as a light management controller. The company who made the ballast sent me the attached document and I was wondering if there was a way I could use some sort of serial.write() to control the ballast using my Arduino.
Thankyou in advance!
Ballast.pdf (452 KB)
isaacs77:
Hi guys,
Certainly, if you are up to reverse engineering their controller.
Paul
Hi ive tried to pull the data from the microcontroller on the PCB however it is apparently impossible.
They use a rs485 signal and I was wondering if you know of any way to read this signal and maybe replicate it with my own microcontroller?
isaacs77:
Then you should have mention in your first post that you have the controller in hand and the electrical part of the serial is RS-485.
Did you study the signal with a recording oscilloscope?
There are boards available to convert the Arduino TTL serial to RS-485. Did you use one?
Paul
I have not used an oscilloscope as wouldn't it only show me waveforms? I have this device:
and i have used it to learn that the signal being sent from the controller is 0x1A 0x00 0x00 0x1F 0x00
i tried to send that signal using the same setup to the ballast however nothing happened ( the controller light on the ballast did not flash like it does when its connected to an actual controller)
I can only presume that the aforementioned hardware is not bi-directional and cannot send output signals.
or maybe there is some form of signal acknowledgment between the ballast and the controller i have not picked up?
Is there any way i can use an Arduino to send this signal?
i appreciate your assistance.
