Controlling KK2 Multirotor Board with Arduino Uno
Hi. I'm trying to control my quadcopter with my arduino uno. I'm trying to have the uno act as the radio receiver and output a ppm signal to the kk2 board. So far, I've been using .writeMicroseconds(); to output my code, but when I have new outputs being continously written to the kk, the motors on my quadcopter turn on and off at seemingly random intervals...
Here is my code:
#include <string.h>
#include <Servo.h>
Servo throttle;
Servo ail;
Servo elev;
Servo rud;
throttle.attach(5);
ail.attach(10);
elev.attach(9);
rud.attach(6);
 throttle.write(0);
   rud.write(1187);
   Serial.println("ARMED");
int data[4];
if (Serial.available()) {
   data[0] = (Serial.parseInt());
  Serial.print("Data0: ");
  Serial.println(data[0]);
  data[1] = (Serial.parseInt());
  Serial.print("Data1: ");
  Serial.println(data[1]);
   data[2] = (Serial.parseInt());
  Serial.print("Data2: ");
  Serial.println(data[2]);
   data[3] = (Serial.parseInt());
  Serial.print("Data3: ");
  Serial.println(data[3]);
  throttle.writeMicroseconds(data[0]);
Serial.println("DID IF");
delete data;
Serial.println("end");
So, when I manually type '1500' in the serial window, the motors run until I send '0' in the serial window. However, when I send the signals with my java-side program, the motors turn on and off continously.....
This is my java-side code if you want to take a look at it....
* Copyright (C) 2012-206 Leap Motion, Inc. All rights reserved. *
* Leap Motion proprietary and confidential. Not for distribution. *
* Use subject to the terms of the Leap Motion SDK Agreement available at *
* https://developer.leapmotion.com/sdk_agreement, or another agreement *
* between Leap Motion and you, your company or other organization. *
import gnu.io.CommPort;
import gnu.io.CommPortIdentifier;
import gnu.io.SerialPort;
import com.leapmotion.leap.*;
import java.io.IOException;
import com.leapmotion.leap.Gesture.State;
import java.io.OutputStream;
import com.leapmotion.leap.Controller;
import com.leapmotion.leap.Frame;
import com.leapmotion.leap.Listener;
//import java.lang.Math;
class SampleListenerMain extends Listener {
	public int posmapxold = 0;
	public int posmapyold = 0;
	public int posmapzold = 0;
	public int a = 1;
public void onInit(Controller controller) {
System.out.println("Initialized");
public void onConnect(Controller controller) {
System.out.println("Connected");
controller.enableGesture(Gesture.Type.TYPE_SWIPE);
controller.enableGesture(Gesture.Type.TYPE_CIRCLE);
controller.enableGesture(Gesture.Type.TYPE_SCREEN_TAP);
controller.enableGesture(Gesture.Type.TYPE_KEY_TAP);
public void onDisconnect(Controller controller) {
System.out.println("Disconnected");
public void onExit(Controller controller) {
System.out.println("Exited");
public void onFrame(Controller controller) {
Frame frame = controller.frame();
Hand hand = frame.hands().rightmost();
float positionx = hand.palmPosition().getX();
System.out.println("X: " + positionx);
float positiony = hand.palmPosition().getY();
System.out.println("Y:" + positiony);
float positionz = hand.palmPosition().getZ();
System.out.println("Z: " + positionz);
System.out.println("Hands: " + frame.hands().count());
int in_min = -117;
int in_max = 117;
int out_min = 900;
int out_max = 1900;
int in_min2 = -73;
int in_max2 = 73;
int positionmapx = (int) ((positionx - in_min) * (out_max - out_min) / (in_max - in_min)) + out_min;
int positionmapy = (int) ((positiony - in_min) * (out_max - out_min) / (in_max - in_min)) + out_min;
int positionmapz = (int) ((positionz - in_min) * (out_max - out_min) / (in_max2 - in_min)) + out_min;
if (frame.hands().count() == 0) {
	//LeapDrone.writeToArduino("0");
String data = Integer.toString(positionmapy)+":"+ Integer.toString(positionmapx)+":"+Integer.toString(positionmapz);
System.out.println("data: " + data);
System.out.println("Old X: " + posmapxold);
System.out.println("Difference X: " + Math.abs(positionmapx - posmapxold));
System.out.println("sent");
	LeapDrone.writeToArduino(data);
/*if (Math.abs(positionmapx - posmapxold) >= 5 && posmapxold > 0) {
//LeapDrone.writeToArduino("100:100:100:100");
if (Math.abs(positionmapy - posmapyold) >= 5 && posmapyold > 0) {
if (Math.abs(positionmapz - posmapzold) >= 5 && posmapzold > 0) {
posmapxold = positionmapx;
posmapyold = positionmapy;
posmapzold = positionmapz;
System.out.println("New-Old X: " + posmapxold);
GestureList gestures = frame.gestures();
for (int i = 0; i < gestures.count(); i++) {
	Gesture gesture = gestures.get(i);
class LeapDrone {
static OutputStream out = null;
public static void main(String[] args) {
//Connect to Arduino BT
try
(new LeapDrone()).connect("/dev/cu.usbmodem1421");
catch ( Exception e )
e.printStackTrace();
System.exit(0);
// Create a sample listener and controller
SampleListenerMain listener = new SampleListenerMain();
Controller controller = new Controller();
// Have the sample listener receive events from the controller
controller.addListener(listener);
// Keep this process running until Enter is pressed
System.out.println("Press Enter to quit...");
try {
System.in.read();
} catch (IOException e) {
// Remove the sample listener when done
controller.removeListener(listener);
void connect ( String portName ) throws Exception {
CommPortIdentifier portIdentifier = CommPortIdentifier.getPortIdentifier(portName);
if ( portIdentifier.isCurrentlyOwned() )
System.out.println("Error: Port is currently in use");
CommPort commPort = portIdentifier.open(this.getClass().getName(),2000);
if ( commPort instanceof SerialPort )
SerialPort serialPort = (SerialPort) commPort;
serialPort.setSerialPortParams(9600,SerialPort.DATABITS_8,SerialPort.STOPBITS_1,
SerialPort.PARITY_NONE);
out = serialPort.getOutputStream();
System.out.println("Error: Only serial ports are handled by this example.");
public static void writeToArduino(String data)
String tmpStr = data;
byte bytes[] = tmpStr.getBytes();
try {
out.write(bytes);
} catch (IOException e) { }
Please read this
// Per.
I read that before posting.... What is wrong with my post?
Zorse:
  1. If you are posting code or error messages, use "code" tags
// Per.
I fixed it! I just increased the baud rate to 115200 and that worked... I guess it was transmitting '0' in between the actual messages so increasing the frequency fixed it! :smiley:
   rud.write(1187);
Shouldn't that be .writeMicroseconds()?
Zorse:
Hi Zorse,
I hope you still around to answer my post :slight_smile:
I'm interested in controlling a KK2 flight controller too with a leap device. I was wondering where did you get the documentation / information to use the leap motion device with java code plz?
Thanks :slight_smile:
Dim
