Controlling LCD display with sensors delay issue
Hello all, I have an issue of LCD displaying. For my project, I need to use multiple sensors to control different areas of the LCD. For now, I just divided the LCD display into 3 regions. And one more important feature of my project is that the sensors should be controlled independently, which means that if I press three sensors, three regions will light up.
Now I have an issue that when I press sensors, the regions on LCD will be on, but there is a big delay, sometimes it does not even work. Could someone help me?
i am using HiLetgo 3.2" IPS TFT LCD Display ILI9481 480X320 and Arduino Mega 2560
Code is here:
#include <TFT_HX8357.h> // Hardware-specific library
TFT_HX8357 tft = TFT_HX8357();       // Invoke custom library
#define sensor1 2
#define sensor2 3
#define sensor3 4
#define sensor4 5
#define sensor5 6
byte lastSensor1State;
byte lastSensor2State;
byte lastSensor3State;
byte lastSensor4State;
byte lastSensor5State;
//Timer variables used
unsigned long currentMillis;
unsigned long pin13Millis;
unsigned long SwitchMillis;
//if these are not changed in the sketch, they can be const
unsigned long debounceMillis = 20UL;  //10ms
unsigned long ledOnTime      = 500UL; //500ms seconds
//void loop() {
//  // put your main code here, to run repeatedly:
//  tft.fillRect(5, 3, 230, 119, TFT_WHITE);
//  tft.fillRect(5, 3, 230, 119, TFT_BLACK);
//  tft.fillRect(240, 125, 230, 119, TFT_WHITE);
//  tft.fillRect(240, 125, 230, 119, TFT_BLACK);
//  tft.fillRect(240, 3, 230, 119, TFT_WHITE);
//  tft.fillRect(240, 3, 230, 119, TFT_BLACK);
//  tft.fillRect(5, 125, 230, 119, TFT_WHITE);
//  tft.fillRect(5, 125, 230, 119, TFT_BLACK);
  tft.init();
  tft.setRotation(1);
  pinMode(sensor1, INPUT_PULLUP);
  pinMode(sensor2, INPUT_PULLUP);
  pinMode(sensor3, INPUT_PULLUP);
  pinMode(sensor4, INPUT_PULLUP);
  pinMode(sensor5, INPUT_PULLUP);
} //END of setup()
  //save the current time
  currentMillis = millis();
  //Heartbeat LED
  //Toggle LED on and off, helps show if there is blocking code
  if (currentMillis - pin13Millis >= ledOnTime)
    pin13Millis = millis();             //re-initialize Timer
    digitalWrite(13, !digitalRead(13)); //toggle LED condition
  //is it time to check the switches?
  if (currentMillis - SwitchMillis >= debounceMillis)
    //code here runs every debounceMillis ms
    SwitchMillis = millis(); //re-initilize Timer
    //go check the switches
    checkSwitches();
} //END of loop()
//                  c h e c k S w i t c h e s ( )
void checkSwitches()
  //reusable for all the switches
  boolean thisState;
  //check if this switch has changed state
  thisState = digitalRead(sensor1);
  if (thisState != lastSensor1State)
    //update the switch state
    lastSensor1State = thisState;
    //this switch position has changed so do some stuff
    //"LOW condition code"
    //has switch gone from HIGH to LOW?
    if (thisState == LOW)
      //Do some LOW switch stuff here
      //Do some HIGH switch stuff here
  } //END of sensor1 code
  thisState = digitalRead(sensor2);
  if (thisState != lastSensor2State)
    lastSensor2State = thisState;
  } //END of sensor2 code
  thisState = digitalRead(sensor3);
  if (thisState != lastSensor3State)
    lastSensor3State = thisState;
  } //END of sensor3 code
} //END of checkSwitches()
