Howdy!
So I'm try to control the turning on and off of an LCD using an IR remote. I first tried to put the 5v through a transistor and using a digital pin to enable the screen, but this failed. Tried to run the LCD GND through the transistor, fail.
I tried the same with a 4N28 optocoupler and if I run the 5v through it, it barely powers the LCD. If I run the GND through it I get absolutely nothing going to the LCD. I believe running the GND would be the proper way to do it.
Any suggestions as to what I am doing wrong? Many thanks!
(cut down diagram to simplify, can provide full sketch if it would be helpful)
To save power. So the main function is to be a camera dolly. Im using the IR and LCD to set a heap of values before pressing "run" which could run for 1-3hrs. I want to knock off the LCD just before that point.
It shouldn't have failed if you did it correctly. You want to use your digital pin to control a PNP transistor as a 'high side switch'. When I did a Google search for 'PNP high side search' I got lots of answers. You would substitute your LCD power pin (usually pin 2) and/or your backlight pin (usually pin 15) for the top part of the 'load' and the LCD GND (pins 1 and/or 16) for the bottom part.
