Controlling LCD with mux
Hello!
I have brought this 20x4 LCD: http://www.sparkfun.com/products/256 and am trying to get it to work with this 4:16 mux: http://www.sparkfun.com/products/9056 . I am able to control other thinks like LEDs, read the value from at potentiometer and turn on a laser. But I have big trouple in controlling my LCD. I have been trying to modify the LiquidCrystal library so that I would change the mux-port just before each digitalwrite within this library and even tried with a delay in between. All with no luck. I have been searching google (a lot!) just cant seem to find any ideas.
Any ideas? please help.
By Jonas
There are 8 data lines in parallel, you can't multiplex them. To save a digital pin, probably you can try to switch a mode of LCD to 4 data bits, check doc if it's supported by controller of the LCD.
You can use as few as 6 pins to control that display. Or if you get a serial back pack, just 2 pins. Sparkfun sells such backpack. Just in case you're interested, I also have a serial LCD keypad panel with much more functions than sparkfun. You can get the back pack version since you already have the display.
http://www.sparkfun.com/products/258
http://www.inmojo.com/store/liudr-arduino-and-physics-gadgets/item/serial-20x4-lcd-keypad-panel---phi-panel/
Thank you guys! So that is why people seem to use a shift register.. I think I will give the siftreg a try, since it is the cheapest :D
