Hello. As the subject states, I am trying to control a 5 meter RGB LED strip with infrared input from a remote. Right now, I have most of the code working. However, when I try to toggle the LED’s down to 10% brightness on any color except red, green or blue, the LED’s flicker like a candle. Can anybody help? To answer any hardware based inquires, I am using 3 MOSFETS, one for each color, I have the ground for the IR sensor, and the LED driver board connected and they are connected to the arduino.
The code is attached below: (I realize that it can be convoluted in some places,that it isn’t always consistent, and that there are large chunks commented out) Thank you in advance!
#include <IRremote.h>
// I/O pins for LED/Arduino connection
int REDPIN = 10;
int GREENPIN = 9;
int BLUEPIN = 6;
int RECV_PIN = 3;
int RELAYPIN = 13;
IRrecv irrecv(RECV_PIN);
decode_results results;
const int TIME = 12000;
// Remote control IR button values
const int POWER = 16712445;
const int RED = 16718565;
const int GREEN = 16751205;
const int BLUE = 16753245;
const int WHITE = 16720605;
const int PINK = 16734375;
const int UPBRIGHT = 16726725;
const int DOWNBRIGHT = 16759365;
const int FADESEVEN = 16769055;
const int FADETHREE = 16736415;
const int JUMPSEVEN = 16752735;
const int JUMPTHREE = 16720095;
const int FASTER = 16771095;
const int SLOWER = 16762935;
const int DIYONE = 16724175;
const int DIYTWO = 16756815;
const int DIYTHREE = 16740495;
const int DIYFOUR = 16716015;
const int DIYFIVE = 16748655;
const int DIYSIX = 16732335;
const int UPRED = 16722135;
const int DOWNRED = 16713975;
const int UPGREEN = 16754775;
const int DOWNGREEN = 16746615;
const int UPBLUE = 16738455;
const int DOWNBLUE = 16730295;
const int DOORONE = 16736925;
const int DOORTWO = 16745085;
const int DOORTHREE = 1784778242;
// LED Fade timer (Make higher to slow down)
int FADESPEED = 5;
// LED States
boolean powerState = false;
int currentState;
int lastColor = WHITE;
boolean bright = true;
int brightness[3] = {230, 127, 0};
int brightnessCoef = 2;
int red[3] = {255, 0, 0};
int green[3] = {0, 255, 0};
int blue[3] = {0, 0, 255};
int white[3] = {255, 150, 200};
int pink[3] = {255, 0, 212};
int* currentColor = white;
int currentR;
int currentG;
int currentB;
/*boolean fadeSev = false;
boolean fadeThr = false;
boolean jumpSev = false;
boolean jumpThr = false;
irrecv.enableIRIn(); // Start Reciever
pinMode(RELAYPIN, OUTPUT);
pinMode(REDPIN, OUTPUT);
pinMode(GREENPIN, OUTPUT);
pinMode(BLUEPIN, OUTPUT);
pinMode(RECV_PIN, INPUT);
/* for(int x = 0; x < 255; x++) {
analogWrite(REDPIN, x);
delay(10);
for (int x = 255; x > 0; x--)
delay(10);
void openDoor(){
digitalWrite (RELAYPIN, HIGH); // relay conduction;
delay (TIME);
//digitalWrite (relay, LOW); // relay switch is turned off;
//delay (time / 3);
//digitalWrite (relay, HIGH); // relay conduction;
//delay (time);
digitalWrite (RELAYPIN, LOW); // relay switch is turned off;
delay (TIME/6);
//Set the color of the LED's
void setColor(){
currentR = map(brightness[brightnessCoef], 0, 255, 0, currentColor[0]);
currentG = map(brightness[brightnessCoef], 0, 255, 0, currentColor[1]);
currentB = map(brightness[brightnessCoef], 0, 255, 0, currentColor[2]);
analogWrite(REDPIN, currentColor[0] - currentR);
analogWrite(GREENPIN, currentColor[1] - currentG);
analogWrite(BLUEPIN, currentColor[2] - currentB);
void loop(){
//Read the IR input and decode it to a result.
if ((irrecv.decode(&results))){
Serial.println(results.value, DEC);
irrecv.resume(); // Receive the next value
//Check the IR input against the power button.
if(results.value == POWER || currentState == POWER){
if(powerState == true){
powerState = false;
digitalWrite(REDPIN, LOW);
digitalWrite(GREENPIN, LOW);
digitalWrite(BLUEPIN, LOW);
else {
powerState = true;
currentState = lastColor;
//if the power is on, allow the lights to be controlled
//check results against the brightness up and down buttons
if(results.value == 16726725 && brightnessCoef < 2){
brightnessCoef++;
else if(results.value == 16759365 && brightnessCoef > 0){
brightnessCoef--;
// check results against button codes and change the lights accordingly.
/*if(results.value == RED || currentState == RED){
currentColor = red;
lastColor = RED;
else if(results.value == GREEN || currentState == GREEN){
currentColor = green;
lastColor = GREEN;
else if(results.value == BLUE || currentState == BLUE){
currentColor = blue;
lastColor = BLUE;
else if(results.value == WHITE || currentState == WHITE){
lastColor = WHITE;
else if(results.value == PINK || currentState == PINK){
currentColor = pink;
lastColor = PINK;
//RED
if(results.value == 16718565){
currentColor = red;
lastColor = RED;
//GREEN
else if(results.value == 16751205){
lastColor = GREEN;
//BLUE
else if(results.value == 16753245){
lastColor = BLUE;
//WHITE
else if(results.value == 16720605){
lastColor = WHITE;
//PINK
else if(results.value == 16734375){
lastColor = PINK;
setColor();
currentState = results.value;
results.value = 0;
