Controlling LED brightness by time of day
Hello all,
I am an arduino noob, and am having a heck of a time figuring out how to write a simple script to adjust the brightness of some LEDs depending on the time of day. Ideally, I would like to set it up using TimeLord.h since that seems to be a fairly good library. However, I'm honestly not sure where to even start.
This is the project I'm working on.
And the code used is below (removed some to fit character count, full code here): any guidance on where to start, or even just have it be one value from 6a-6p and a second from 6p-6a would be great.
Thanks in advance for any help!
#include <ESP8266WiFi.h>
#include <FastLED.h>
#include <vector>
using namespace std;
#define FASTLED_ESP8266_RAW_PIN_ORDER
#define DEBUG false
int status = WL_IDLE_STATUS;
// Define the array of leds
CRGB leds[NUM_AIRPORTS];
#define DATA_PIN    5
#define LED_TYPE    WS2811
#define COLOR_ORDER RGB
#define BRIGHTNESS 20
std::vector<unsigned short int> lightningLeds;
std::vector<String> airports({
  "KKIC", // order of LEDs, starting with 1 should be KKIC; use VFR, WVFR, MVFR, IFR, LIFR for key; NULL for no airport
  "KMRY", // 2
  "KSNS", // 3
  "KCVH", // 4
  "KE16", // 5
  "KWVI", // 6
  "KRHV", // 7
  "KSJC", // 8
  "KNUQ", // 9
  "KPAO", // 10
  "KSQL", // 11
  "KHAF", // 12
  "KSFO", // 13
  "KOAK", // 14
  "KHWD", // 15
  "KLVK", // 16
  "KC83", // 17
  "NULL", // 18 empty
  "KCCR", // 19
  "KSUU", // 20
  "KVCB", // 21
  "KAPC", // 22
  "KDVO", // 23
  "KO69", // 24
  "KSTS", // 25
  "KHES", // 26
  "NULL", // 27 empty
  "KUKI", // 28
  "KRBL", // 29
  "NULL", // 30 empty
  "KCIC", // 31
  "NULL", // 32 empty
  "KOVE", // 33
  "NULL", // 34 empty
  "KMYV", // 35
  "KBAB", // 36
  "KAUN", // 37
  "KLHM", // 38
  "KSMF", // 39
  "KEDU", // 40
  "KSAC", // 41
  "KMCC", // 42
  "KMHR", // 43
  "NULL", // 44 empty
  "KPVF", // 45
  "NULL", // 46 empty
  "KBLU", // 47
  "KTRK", // 48
  "NULL", // 49 empty
  "KTVL", // 50
  "KO22", // 51
  "KCPU", // 52
  "KJAQ", // 53
  "NULL", // 54 empty
  "KSCK", // 55
  "KMOD", // 56
  "NULL", // 57 empty
  "KMER", // 58
  "KMCE", // 59
  "NULL", // 60 empty
  "KMAE", // 61
  "KO88" // 62
  //Initialize serial and wait for port to open:
  Serial.begin(74880);
  //pinMode(D1, OUTPUT); //Declare Pin mode
  //while (!Serial) {
  //    ; // wait for serial port to connect. Needed for native USB
  pinMode(LED_BUILTIN, OUTPUT); // give us control of the onboard LED
  digitalWrite(LED_BUILTIN, LOW);
  // Initialize LEDs
  FastLED.addLeds<LED_TYPE, DATA_PIN, COLOR_ORDER>(leds, NUM_AIRPORTS).setCorrection(TypicalLEDStrip);
  FastLED.setBrightness(BRIGHTNESS);
  digitalWrite(LED_BUILTIN, LOW); // on if we're awake
  int c;
  const unsigned int lightningLoopThreshold = REQUEST_INTERVAL / LIGHTNING_INTERVAL;
      return;
    Serial.println("OK!");
    if (ledStatus) fill_solid(leds, NUM_AIRPORTS, CRGB::Purple); // indicate status with LEDs
    FastLED.show();
    ledStatus = false;
    FastLED.show();
    delay(25);
    for (unsigned short int i = 0; i < lightningLeds.size(); ++i) {
      unsigned short int currentLed = lightningLeds[i];
      leds[currentLed] = lightning[i]; // restore original color
    FastLED.show();
    digitalWrite(LED_BUILTIN, HIGH);
    delay(LIGHTNING_INTERVAL); // pause during the interval
  if (lightningLeds.size() == 0 || !DO_LIGHTNING || lightningLoops >= lightningLoopThreshold) {
    if (DEBUG) {
      fill_gradient_RGB(leds, NUM_AIRPORTS, CRGB::Red, CRGB::Blue); // Just let us know we're running
      FastLED.show();
    Serial.println("Getting METARs ...");
    if (getMetars()) {
      Serial.println("Refreshing LEDs.");
      FastLED.show();
      if (DO_LIGHTNING && lightningLeds.size() > 0) {
        lightningLoops = 0;
        Serial.println("There is lightning, so no long sleep.");
        Serial.print("No lightning; Going into sleep for: ");
        Serial.println(REQUEST_INTERVAL);
        delay(REQUEST_INTERVAL); // delay 10 seconds to give it time to go
      delay(RETRY_TIMEOUT); // try again if unsuccessful
            doColor(currentAirport, led, currentWind.toInt(), currentGusts.toInt(), currentCondition, currentWxstring);
          currentAirport = ""; // Reset everything when the airport changes
          readingAirport = true;
          currentCondition = "";
          currentWind = "";
          currentGusts = "";
          currentWxstring = "";
        } else if (readingAirport) {
          if (!currentLine.endsWith("<")) {
            currentAirport += c;
            readingAirport = false;
            for (unsigned short int i = 0; i < NUM_AIRPORTS; i++) {
              if (airports[i] == currentAirport) {
                led = i;
        } else if (currentLine.endsWith("<wind_speed_kt>")) {
          readingWind = true;
        } else if (readingWind) {
            currentWind += c;
            readingWind = false;
        } else if (currentLine.endsWith("<wind_gust_kt>")) {
          readingGusts = true;
        } else if (readingGusts) {
            currentGusts += c;
            readingGusts = false;
        } else if (currentLine.endsWith("<flight_category>")) {
          readingCondition = true;
        } else if (readingCondition) {
            currentCondition += c;
            readingCondition = false;
        } else if (currentLine.endsWith("<wx_string>")) {
          readingWxstring = true;
        } else if (readingWxstring) {
            currentWxstring += c;
            readingWxstring = false;
        t = millis(); // Reset timeout clock
      } else if ((millis() - t) >= (READ_TIMEOUT * 1000)) {
        Serial.println("---Timeout---");
        fill_solid(leds, NUM_AIRPORTS, CRGB::Cyan); // indicate status with LEDs
        FastLED.show();
        ledStatus = true;
        client.stop();
        return false;
  // need to doColor this for the last airport
  // Do the key LEDs now if they exist
  for (int i = 0; i < (NUM_AIRPORTS); i++) {
    // Use this opportunity to set colors for LEDs in our key then build the request string
    if (airports[i] == "VFR") leds[i] = CRGB::Green;
    else if (airports[i] == "WVFR") leds[i] = CRGB::Yellow;
    else if (airports[i] == "MVFR") leds[i] = CRGB::Blue;
    else if (airports[i] == "IFR") leds[i] = CRGB::Red;
    else if (airports[i] == "LIFR") leds[i] = CRGB::Magenta;
  client.stop();
  return true;
void doColor(String identifier, unsigned short int led, int wind, int gusts, String condition, String wxstring) {
  CRGB color;
  Serial.print(identifier);
  Serial.print(": ");
  Serial.print(condition);
  Serial.print(" ");
  Serial.print(wind);
  Serial.print("G");
  Serial.print(gusts);
  Serial.print("kts LED ");
  Serial.print(led);
  Serial.print(" WX: ");
  Serial.println(wxstring);
  if (wxstring.indexOf("TS") != -1) {
    Serial.println("... found lightning!");
    lightningLeds.push_back(led);
  if (condition == "LIFR" || identifier == "LIFR") color = CRGB::Magenta;
  else if (condition == "IFR") color = CRGB::Red;
  else if (condition == "MVFR") color = CRGB::Blue;
  else if (condition == "VFR") {
    if ((wind > WIND_THRESHOLD || gusts > WIND_THRESHOLD) && DO_WINDS) {
      color = CRGB::Yellow;
      color = CRGB::Green;
  } else color = CRGB::Black;
  leds[led] = color;
First of all, welcome to the forum. Props for using code tags (as well as URL tags). If you want to know the time of day, you either need a real time clock (RTC) or connect to some Time service. After you figure out what time it is, you can modify the intensity based of that time.
How do you want to fade the LEDs with time?
Faded down for night time, then fade up through morning to full brightness all day, then fade down in the evening for nighttime level again.
Or is it to compensate for room brightness?
PS Thanks for reading the forum instructions, makes reading a first post so much easier.
Have a look at the fade examples and write a simple sketch to fade an LED:
Then look at the time examples with your library . Assign a variable to “brightness “ and vary it’s value at different times of the day ( look at “case”, “IF” , or “arrays” ) , then use that to vary the brightness of the leds ( look at analog examples) .
Get that working then fit that into your main sketch .
