Controlling LED Brightness Using ESP32
// the number of the LED pin
const int ledPin = 16;  // 16 corresponds to GPIO16
// setting PWM properties
const int freq = 5000;
const int ledChannel = 0;
const int resolution = 8;
void setup(){
  // configure LED PWM functionalitites
  ledcSetup(ledChannel, freq, resolution);
  // attach the channel to the GPIO to be controlled
  ledcAttachPin(ledPin, ledChannel);
void loop(){
  // increase the LED brightness
  for(int dutyCycle = 0; dutyCycle <= 255; dutyCycle++){
    // changing the LED brightness with PWM
    ledcWrite(ledChannel, dutyCycle);
    delay(15);
  // decrease the LED brightness
  for(int dutyCycle = 255; dutyCycle >= 0; dutyCycle--){
    delay(15);
Arduino: 1.8.19 (Windows 10), Board: "Arduino Mega or Mega 2560, ATmega2560 (Mega 2560)"
C:\Users\DELL\Desktop\Arduinoprojects\DRIVER_BRIGHTNESS\DRIVER_BRIGHTNESS.ino: In function 'void setup()':
DRIVER_BRIGHTNESS:11:3: error: 'ledcSetup' was not declared in this scope
DRIVER_BRIGHTNESS:14:3: error: 'ledcAttachPin' was not declared in this scope
C:\Users\DELL\Desktop\Arduinoprojects\DRIVER_BRIGHTNESS\DRIVER_BRIGHTNESS.ino: In function 'void loop()':
DRIVER_BRIGHTNESS:21:5: error: 'ledcWrite' was not declared in this scope
C:\Users\DELL\Desktop\Arduinoprojects\DRIVER_BRIGHTNESS\DRIVER_BRIGHTNESS.ino:21:5: note: suggested alternative: 'bitWrite'
     bitWrite
DRIVER_BRIGHTNESS:28:5: error: 'ledcWrite' was not declared in this scope
C:\Users\DELL\Desktop\Arduinoprojects\DRIVER_BRIGHTNESS\DRIVER_BRIGHTNESS.ino:28:5: note: suggested alternative: 'bitWrite'
     bitWrite
exit status 1
Invalid library found in C:\Users\DELL\Documents\Arduino\libraries\ArduinoJson: no headers files (.h) found in C:\Users\DELL\Documents\Arduino\libraries\ArduinoJson
Invalid library found in C:\Users\DELL\Documents\Arduino\libraries\FreeRTOS-main: no headers files (.h) found in C:\Users\DELL\Documents\Arduino\libraries\FreeRTOS-main
Invalid library found in C:\Users\DELL\Documents\Arduino\libraries\LED-Specification-sheets: no headers files (.h) found in C:\Users\DELL\Documents\Arduino\libraries\LED-Specification-sheets
Invalid library found in C:\Users\DELL\Documents\Arduino\libraries\LedCubeTeensy-master: no headers files (.h) found in C:\Users\DELL\Documents\Arduino\libraries\LedCubeTeensy-master
Invalid library found in C:\Users\DELL\Documents\Arduino\libraries\SPI: no headers files (.h) found in C:\Users\DELL\Documents\Arduino\libraries\SPI
Invalid library found in C:\Users\DELL\Documents\Arduino\libraries\u8g2-master: no headers files (.h) found in C:\Users\DELL\Documents\Arduino\libraries\u8g2-master
option enabled in File -> Preferences.
I have to control LED Strip brightness using ESP32 and I got this error can anyone help me on this
Where are ledcxxx being defined or declared ?
Probably in a missing library or support file.
It's a command no need to declare or define
you have not chosen an ESP32 - the Arduino Mega doesn't know ledcSetup. Chose the ESP32 as board and you shouldn't get this error.
Arduino: 1.8.19 (Windows 10), Board: "Generic ESP8266 Module, 80 MHz, Flash, Disabled (new aborts on oom), Disabled, All SSL ciphers (most compatible), 32KB cache + 32KB IRAM (balanced), Use pgm_read macros for IRAM/PROGMEM, dtr (aka nodemcu), 26 MHz, 40MHz, DOUT (compatible), 1MB (FS:64KB OTA:~470KB), 2, nonos-sdk 2.2.1+100 (190703), v2 Lower Memory, Disabled, None, Only Sketch, 115200"
   11 |   ledcSetup(ledChannel, freq, resolution);
DRIVER_BRIGHTNESS:15:3: error: 'ledcAttachPin' was not declared in this scope
   15 |   ledcAttachPin(ledPin, ledChannel);
DRIVER_BRIGHTNESS:22:5: error: 'ledcWrite' was not declared in this scope
   22 |     ledcWrite(ledChannel, dutyCycle);
DRIVER_BRIGHTNESS:29:5: error: 'ledcWrite' was not declared in this scope
   29 |     ledcWrite(ledChannel, dutyCycle);
exit status 1
Now I have tried with Esp8266 then also I get this error
you have written you have an ESP32.
you must chose an ESP32 (not an ESP8286).
Thankyou
