Controlling LED power with Mosfet
I am trying to control a 3W RGB LED (total 9W) by using a Mosfet on each channel, where the supply voltage is 12V. Each channel is supposed to be good for 700mA continuous. If I put my multimeter in the circuit and measure current, do I look at DC or AC current?
I am switching the mosfet using an Arduino Uno using analogWrite. I found if I ramp up to 40 (40 out of 256 = 16%) I read ~ 650mA AC, and about 300mA DC. I know the real current is pulsing all around but I'm assuming the average current is what is important to the LED, is the DC value a realistic measure of the average current into the LED?
Thanks
You assume incorrectly it is he peak current that matters as well.
A meter will not give a sensible reading for pulsed current, which is why you have.
What are you using to limit the current? You can not connect a power led up directly to a power source even through a FET. Normally some sort of constant current drive is needed.
I needed to set up something quickly and I didn't have a 700mA driver. I found it has worked pretty well so far. I'll scope the voltages/current later when the project is not in service. Nothing has burned out and it's not too hot so I think there's enough smoothing in the circuit to limit the peak voltage/current. Sorry I'm not too experienced with circuits like these. I had the PWM up to 130/256 = 51% which I slowly ramped up to incrementally until the brightness seemed right. PWM frequency I think is ~500 - 1000 Hz. I'll try a LPF.
So you think so do you, despite admitting:-
So what smoothing is this then?
It is a well known fact that and excuse like this invalidates the laws of physics.
I can only advise you on doing things correctly.
