Controlling LIDAR, Motor and Encoder
Hi all, for this project i am building a sort of 'radar' using tfmini lidar that spins using a nema 17 motor and rotary encoder for positional data.
I am using an arduino Nano and am using a pin change interrupt for the encoder which works fine. With regard to the lidar and motor, i want a fast sampling rate for the lidar and a steady constant velocity for the motor.
My first approach was to use the AccelStepper library and have this in the motor function
  Lidar();
  motor ();
void motor ()
  stepper.setSpeed(500);
  stepper.run();
void Lidar()
  uint16_t dist = tfmini.getDistance();
  uint16_t strength = tfmini.getRecentSignalStrength();
  Serial.println(dist);
  Serial.print(" cm      sigstr: ");
  Serial.println(strength);
However thus results in a fast sample rate for the Lidar but a 'jerky' and slow response from the motor.
I then used a different approach not using the library
  Lidar();
  motor ();
void motor ()
  digitalWrite(dirPin,HIGH);
  for(int x = 0; x < 200; x++) {
    digitalWrite(stepPin,HIGH);
    delayMicroseconds(2000);
    digitalWrite(stepPin,LOW);
void Lidar()
This results in a good steady motor speed but due to the 'delay' the Lidar sample rate is slow.
My next thoughts were to
-use a second interrupt on the lidar but this has had no succes thus far
-research into arduino RTOS
-use a second microcontroller for the motor functionality
Unless of course you had any other ideas
My full code can be seen here
//Include Libraries
#include <Stepper.h>
#include <EEPROM.h>
#include <SoftwareSerial.h>
#include "TFMini.h"
#include <AccelStepper.h>
//Definitions Motor
#define dirPin 4
#define stepPin 5
#define motorInterfaceType 1
int speed = 500;
AccelStepper stepper = AccelStepper(motorInterfaceType, stepPin, dirPin);
// Setup Serial Port LIDAR
SoftwareSerial mySerial(12, 13);
TFMini tfmini; // Uno RX (TFMINI TX), Board TX (TFMINI RX)
//Definition Encoder
int pinA = 2;
int pinB = 3;
int encoderPosCount = 0; //EEPROM.read(encoderPosCount);
int encoderInterrupt = 0;
int pinALast;
int aVal = 0;
int address = 0;
  //Motor Setup
  stepper.setMaxSpeed(1000);
  //Encoder Setup
  pinMode (pinA,INPUT);
  pinMode (pinB,INPUT_PULLUP);
  attachInterrupt(digitalPinToInterrupt(pinB), rotation, CHANGE);
  pinALast = digitalRead(pinA);
  Serial.begin(38400);
  // Wait for Serial Port to Connect
  while (!Serial);
  Serial.println ("Serial Port Found");
  mySerial.begin(TFMINI_BAUDRATE);
  tfmini.begin(&mySerial);
  Lidar();
  motor ();
void motor ()
void Lidar()
void rotation()
  aVal = digitalRead(pinA);
  if (aVal != pinALast)
     if (digitalRead(pinB) != aVal) //We're Rotating Clockwise
       encoderPosCount --;
       Serial.println ("Rotate Clockwise");
       encoderInterrupt = encoderInterrupt + 1;
     else if(encoderPosCount == 118)
       Serial.println("Rotate Counterclockwise");
       encoderPosCount++;
       encoderInterrupt = encoderInterrupt - 1;
     Serial.print("Encoder Count: ");
     Serial.println(encoderPosCount);
     EEPROM.write(address, encoderPosCount);
   pinALast = aVal;
Thanks
