controlling lights with sensor
int inputPin = 2;               // choose the input pin (for PIR sensor)
int pirState = LOW;             // we start, assuming no motion detected
int val = 0;                    // variable for reading the pin status
int ledPin = LED_BUILTIN;
unsigned long previousMillis = 0;
bool state = false;
  pinMode(ledPin, OUTPUT);      // declare LED as output
  pinMode(inputPin, INPUT);     // declare sensor as input
  WiFi.begin(ssid, password);
  Serial.print("Connecting to WiFi");
    Serial.print(".");
  Serial.println("Connected to the WiFi network");
  delay(125);
  val = digitalRead(inputPin);  // read input value
  if (val == HIGH) {            // check if the input is HIGH
    digitalWrite(ledPin, HIGH);  // turn LED ON
    if (pirState == LOW) {
      // we have just turned on
      Serial.println("Motion detected!");
      if(state == true) return;
      switchLight(1, true);
      // We only want to print on the output change, not state
      pirState = HIGH;
    digitalWrite(ledPin, LOW); // turn LED OFF
    if(state == false) return;
    switchLight(1, false);
    if (pirState == HIGH){
      // we have just turned of
      Serial.println("Motion ended!");
      pirState = LOW;
void switchLight(byte room, bool current_state){
  state = current_state;
  HTTPClient http;
  String req_string;
  req_string = "http://";
  req_string += ip;
  req_string += "/api/";
  req_string += user_name;
  req_string += "/lights/";
  req_string += light_id;
  req_string += "/state";
  Serial.println(req_string);
  http.begin(req_string);
  http.addHeader("Content-Type", "text/plain");
  String put_string;
  put_string = "{\"on\":";
  put_string += (current_state)? "true" : "false";
  put_string += "}";
  int httpResponseCode = http.PUT(put_string);
  if(httpResponseCode > 0){
    String response = http.getString();
    Serial.println(httpResponseCode);
    Serial.println(response);
    Serial.print("Error on sending PUT Request: ");
   http.end();
a side from providing some of my personal info with is not in this code im having trouble turning the lights off when the sensor detects motion the light will come on however it will not turn off any thoughts?
What do your debug prints tell you about how your code is behaving?
so im not sure but exactly why but it seems like when motion is detected it will go through the loop such as connecting to the wifi and with the print motion detected however then the voltage on the sensor switches to low as it being in the no motion detected state it looks like it just stops at connecting to wifi and dont execute turning off the light
it was the
how can i put a check like that but make it work?
What does "work" mean?
