I'm trying to control a single linear actuator using an Arduino uno.
The control mechanism isn't a problem.
The problem is which is the best (cheapest) way to control actuator using the arduino.
-The actuator is 12 - 20V.
-With that high voltage, I need a way to use a different source of power.
I want vary the speed of the actuator (varying voltage)
I've been considering:
Motor driver: LM324 (But I think 20V is way to high for this).
Using a high voltage relay
Pololu motor driver shield (Last resort. These are expensive.....)
I learning towards using a relay but is there a better way?
so I'm going to use an actuator similar to this one. http://www.servocity.com/html/25_lbs__thrust_linear_actuator.html#.U88AifldUeo
The specifications:
Operating Voltage: 6.0-12 Volts DC
Operating Temp. Range: -26 to +65°C -14.8 to +149°F
Operating Speed (12V): 2.00” second at No load
Operating Speed (12V): 1.37” second at Max load
Dynamic Thrust (12V): 25 lbs. Thrust
Static Load: 500 lbs.
Current Drain (12V): 800ma operating No load
Current drain (12V): 3.8A operating full load
Current drain (12V): 15A at stall
(Warning: Damage can occur at stall)
Motor Type: 3 Pole Ferrite
Potentiometer: I0K
Gear Ratio: 5:1 Ratio
Gear Type: 4 Metal Gears
Connector Wire Length: 24"
Recommended Fuse: 5amp inline
IP Grade: IP 65 - total dust protection, water resistant
Duty Cycle: 25% (25% on, 75% off)
Housing Material: Zinc Alloy
See, I want to make an exoskelaton arm like everyone else.
I was going to use make it push down on a lever to make it contract and relax.
Do you know of any cheap motor drivers that could work for this? Preferably around 15 dollars.
I might consider a better one if I can find a job
