In case anyone is struggling with programming the 3x3 cube from MakerShed. Doesn't really come with much information.
/*Wulf Robotics
//Inspiration for this from Joe Hudy
//Cube Sketch testing,, cubeFace function can handle inner and outer faces
//Set column variables
//Set to HIGH to activate LED, front is with USB port facing you
int p1=10; //Front Left
int p2=7; //Front Middle
int p3=11; //Front Right
int p4=6; //Center Left
int p5=5; //Center
int p6=A0; //Center Right
int p7=2; //Back Left
int p8=4; //Back Middle
int p9=A5; //Back Right
//Set Level variables
int lTop=A4; //Set LOW to activate top layer LEDs
int lMid=A2; //Set to LOW to activate mid layer LEDs
int lBot=A1; //Set to LOW to activate bottom layer LEDs
//Set pins to OUTPUT mode
pinMode(2, OUTPUT);
pinMode(4, OUTPUT);
pinMode(A5, OUTPUT);
pinMode(6, OUTPUT);
pinMode(5, OUTPUT);
pinMode(A0, OUTPUT);
pinMode(10, OUTPUT);
pinMode(7, OUTPUT);
pinMode(11, OUTPUT);
pinMode(A1, OUTPUT);
pinMode(A2, OUTPUT);
pinMode(A4, OUTPUT);
cubeFace(p1, p4, p7, LOW); //turn off left face (Start here to keep look consistent in loop)
cubeFace(p1, p2, p3, HIGH); //turn on front face
delay(250); //slight pause
cubeFace(p1, p2, p3, LOW); //turn off front face
cubeFace(p3, p6, p9, HIGH); //turn on right face
delay(250);
cubeFace(p3, p6, p9, LOW); //turn off right face
cubeFace(p7, p8, p9, HIGH); //turn on back face
delay(250);
cubeFace(p7, p8, p9, LOW); //turn off back face
cubeFace(p1, p4, p7, HIGH); //turn on left face
delay(250);
cubeTop(p1, p2, p3, p4, p5, p6, p7, p8, p9, HIGH); //turn on top face
delay(250); //pause
cubeTop(p1, p2, p3, p4, p5, p6, p7, p8, p9, LOW); //turn off top face
delay(250); //pause
cubeBot(p1, p2, p3, p4, p5, p6, p7, p8, p9, HIGH); //turn on bottom face
delay(250); //pause
cubeBot(p1, p2, p3, p4, p5, p6, p7, p8, p9, LOW); //turn off bottom face
delay(250);
delay(250); //pause
delay(250); //pause
delay(250);
cubeMid(p1, p2, p3, p4, p5, p6, p7, p8, p9, HIGH); //turn on mid face
delay(250);
cubeMid(p1, p2, p3, p4, p5, p6, p7, p8, p9, LOW); //turn off mid face
delay(250);
delay(250);
delay(250);
delay(250); //pause
cubeFace(p2, p5, p8, HIGH); //turn on front vertical slice
cubeFace(p2, p5, p8, LOW); //turn off front vertical slice
cubeFace(p3, p5, p7, HIGH); //turn on right angle slice
delay(250);
cubeFace(p3, p5, p7, LOW); //turn off right angle slice
cubeFace(p4, p5, p6, HIGH); //turn on mid face slice
delay(250);
cubeFace(p4, p5, p6, LOW); //turn off mid face slice
cubeFace(p1, p5, p9, HIGH); //turn on left angle slice
delay(250);
cubeFace(p4, p5, p9, LOW); //turn off left angle slice
delay(250);
delay(250);
void cubeFace(uint8_t left, uint8_t middle, uint8_t right, uint8_t sig) //get columns to choose which face to light from function call above
liteFace(left, middle, right, sig); //pull values passed from original call to cubeFace and pass to liteFace function
digitalWrite(lTop, LOW); //turn on ground to top layer
digitalWrite(lMid, LOW); //turn on ground to middle layer
digitalWrite(lBot, LOW); //turn on ground to bottom layer
void liteFace(uint8_t left, uint8_t middle, uint8_t right, uint8_t sig) //pulls values from cubeFace and turns columns on or off
digitalWrite(left, sig);
digitalWrite(middle, sig);
digitalWrite(right, sig);
void cubeTop(uint8_t one,uint8_t two,uint8_t three,uint8_t four,uint8_t five,uint8_t six,uint8_t seven,uint8_t eight,uint8_t nine,uint8_t sig)
liteLayer(one,two,three,four,five,six,seven,eight,nine,sig); //pull values passed from original call to cubeTop and pass to liteLayer function
digitalWrite(lMid, HIGH); //turn off ground to middle layer
digitalWrite(lBot, HIGH); //turn off groung to bottom layer
void cubeMid(uint8_t one,uint8_t two,uint8_t three,uint8_t four,uint8_t five,uint8_t six,uint8_t seven,uint8_t eight,uint8_t nine,uint8_t sig)
liteLayer(one,two,three,four,five,six,seven,eight,nine,sig); //pull values passed from original call to cubeMid and pass to liteLayer function
digitalWrite(lTop, HIGH); //turn on ground to top layer
digitalWrite(lMid, LOW); //turn off ground to middle layer
void cubeBot(uint8_t one,uint8_t two,uint8_t three,uint8_t four,uint8_t five,uint8_t six,uint8_t seven,uint8_t eight,uint8_t nine,uint8_t sig)
liteLayer(one,two,three,four,five,six,seven,eight,nine,sig); //pull values passed from original call to cubeBot and pass to liteLayer function
digitalWrite(lBot, LOW); //turn off groung to bottom layer
//activates LEDs for whole layer, variables passed from cubeTop, Mid and Bot functions
void liteLayer(uint8_t one,uint8_t two,uint8_t three,uint8_t four,uint8_t five,uint8_t six,uint8_t seven,uint8_t eight,uint8_t nine,uint8_t sig)
digitalWrite(one,sig);
digitalWrite(two,sig);
digitalWrite(three,sig);
digitalWrite(four,sig);
digitalWrite(five,sig);
digitalWrite(six,sig);
digitalWrite(seven,sig);
digitalWrite(eight,sig);
digitalWrite(nine,sig);
