Controlling more than one output via serial & php
Hello guys,
i'm new and I already searched the forums, but i wasn't able to find something regarding my question.
Okay. I don't own an arduino board yet but i want to learn about how to program it, to begin just when it arrives.
so what i want to do is following. i want to control 5-10 (25amps) relays over serial port, using php on a linux server. i have read some tutorials on how to interface php with the arduino board but all of them are utilizing only one output.
i know how to open a connection and write one ascii 1 to the serial port. and i can understand how the arduino code works to process the ascii 1 it just got.
now i want to know, how to identify other pins in the arduino code and in php. are there any tutorials regarding this?
You'll need a few transistors to drive the relays... the Digital pins can't do it alone.
On the software side:
Lets say I have relays plugged into pins 8, 9, 10, 11, and 12. If I wanted to turn 8, 9, and 11 on, I could write
8,1 9,1 10,0 11,1 12,0
to the serial port. Then you could write some arduino software to parse that.
so for one relay i have to write
for example 8,1
8 and 1 to an array and have a for loop scanning all pins for a change right?
You're trying to control the pins according to received serial messages, I thought - why would you want scan pins for a change?
hm. i dont really understand how to take those messages from the serial port, and parse them in my arduino code..
i do
if (Serial.available() > 0) {
usbnumber = Serial.read();
if (usbnumber > 0) {
digitalWrite(ledPin, HIGH);
so at first i open the connection and listen on that for changes.
if theres something higher then 0, i set the ledpin to high.
the thing i dont understand is, which code i need to use for multiple pin-possibilites
//edit:
i just got another idea.
is it possible to get the 8,1 or something as a string from the php code?
i could then write some
String instruction = String(4)
if(instruction.contains(8,1)
set power to pin 8;
right?
Take a look at the C case-switch http://www.arduino.cc/en/Reference/SwitchCase
For example:
int usbnumber;
//Define pin names above
switch (usbnumber) {
    case 5:
//Send a 5 to turn on pin 5
    digitalWrite(5,HIGH);
    case 50:
//Send 50 to turn off pin 5
    digitalWrite(5,LOW);
case 13:
//Send 13 to turn on pin 13
    digitalWrite(13,LOW);
    case 130:
//Send 130 to turn off pin 13
Then just send integers over serial, and change/add to the case loop however you please.
