const int greenLEDPin = 9;
const int redLEDPin = 11;
const int blueLEDPin = 10;
String red = "";
String blue = "";
String green = "";
int redValue = 0;
int greenValue = 0;
int blueValue = 0;
pinMode(greenLEDPin, OUTPUT);
pinMode(redLEDPin, OUTPUT);
pinMode(blueLEDPin, OUTPUT);
Serial.println("Enter red");
red = Serial.readString();
while (Serial.available() == 0) {}
blue = Serial.readString();
Serial.println("Enter blue");
Serial.println("Enter green");
green = Serial.readString();
Serial.println("R:" + red);
Serial.println("B:" + blue);
Serial.println("G:" + green);
red.toInt();
blue.toInt();
green.toInt();
analogWrite(redLEDPin, red);
analogWrite(greenLEDPin, green);
analogWrite(blueLEDPin, blue);
So I'm trying to make an LED light up with set red, blue, and green inputs into the serial monitor. I'm having two problems. First, when my inputs are printed back into the serial monitor, red is empty, whatever I put for red goes into blue, and whatever I put for blue goes into green. And Secondly, I'm not sure how to convert those Strings (my inputs for RGB) into Integers that I can then use as outputs for my LED. The current code gives me an error:
cannot convert 'String' to 'int' for argument '2' to 'void analogWrite(uint8_t, int)'
I'm pretty new to this, so please help nicely Thanks.
String red = "";
String blue = "";
String green = "";
int redValue = 0;
int greenValue = 0;
int blueValue = 0;
red.toInt();
blue.toInt();
green.toInt();
In function 'void loop()':
color_mixer:40:29: error: cannot convert 'String' to 'int' for argument '2' to 'void analogWrite(uint8_t, int)'
color_mixer:41:33: error: cannot convert 'String' to 'int' for argument '2' to 'void analogWrite(uint8_t, int)'
color_mixer:42:31: error: cannot convert 'String' to 'int' for argument '2' to 'void analogWrite(uint8_t, int)'
exit status 1
// install SafeString V3 from Arduino Library manager
#include <SafeString.h>
#include <SafeStringReader.h>
createSafeStringReader(sfReader, 20, " ,\r\n");
int redValue = 0;
int greenValue = 0;
int blueValue = 0;
int waitingFor = 0; // 0, red, 1, blue, 2 green
for (int i = 10; i > 0; i--) {
Serial.print(i); Serial.print(' ');
Serial.println(); sfReader.connect(Serial);
sfReader.echoOn();
sfReader.setTimeout(100); // incase Monitor has No line Ending set
promptForInput(0); // prompt for red
void promptForInput(int waitingFor) {
if (waitingFor == 0) {
Serial.println(" Enter value for Red in the range 0 to 255");
} else if (waitingFor == 1) {
Serial.println(" Enter value for Blue in the range 0 to 255");
Serial.println(" Enter value for Green in the range 0 to 255");
void setValue(int waitingFor, int value) {
redValue = value;
analogWrite(redLEDPin, redValue);
blueValue = value;
analogWrite(blueLEDPin, blueValue);
greenValue = value;
analogWrite(greenLEDPin, greenValue);
void getSettings() {
if (sfReader.read()) {
// see if the input is valid
int setting = 0;
if (sfReader.toInt(setting)) {
// got one
if ((setting < 0) || (setting > 255)) {
Serial.println(" number out of range 0 to 255");
setValue(waitingFor, setting);
waitingFor++;
if (waitingFor > 2) {
waitingFor = 0; // back to red
promptForInput(waitingFor);
Serial.println(" not a valid integer");
getSettings();
Cross-posting is against the rules of the forum. The reason is that duplicate posts can waste the time of the people trying to help. Someone might spend 15 minutes (or more) writing a detailed answer on this topic, without knowing that someone else already did the same in the other topic.
Repeated cross-posting will result in a timeout from the forum.
In the future, please take some time to pick the forum board that best suits the topic of your question and then only post once to that forum board. This is basic forum etiquette, as explained in the sticky "How to use this forum - please read." post you will find at the top of every forum board. It contains a lot of other useful information. Please read it.
