Hello.
By using the code below we can control one led by voice commands.
how can I edit this code in order to control multi led like 3 or 4 for example
- @file vr_sample_control_led.ino
- @author JiapengLi
@brief This file provides a demostration on
how to control led by using VoiceRecognitionModule
@note:
voice control led
- @section HISTORY
2013/06/13 Initial version.
#include <SoftwareSerial.h>
#include “VoiceRecognitionV3.h”
Connection
Arduino VoiceRecognitionModule
2 -------> TX
3 -------> RX
VR myVR(2,3); // 2:RX 3:TX, you can choose your favourite pins.
uint8_t records[7]; // save record
uint8_t buf[64];
int led = 13;
#define onRecord (0)
#define offRecord (1)
@brief Print signature, if the character is invisible,
print hexible value instead.
@param buf → command length
len → number of parameters
void printSignature(uint8_t buf, int len)
int i;
for(i=0; i<len; i++){
if(buf_>0x19 && buf<0x7F){_
_ Serial.write(buf*);
else{
Serial.print("[");
Serial.print(buf, HEX);
Serial.print("]");
@param buf → VR module return value when voice is recognized.
buf[0] → Group mode(FF: None Group, 0x8n: User, 0x0n:System*
* buf[1] → number of record which is recognized.
buf[2] → Recognizer index(position) value of the recognized record.
buf[3] → Signature length*
* buf[4]~buf[n] → Signature*
void printVR(uint8_t *buf)
Serial.println(“VR Index\tGroup\tRecordNum\tSignature”);
Serial.print(buf[2], DEC);
Serial.print("\t\t");
if(buf[0] == 0xFF){
Serial.print(“NONE”);
else if(buf[0]&0x80){
Serial.print(“UG “);
Serial.print(buf[0]&(~0x80), DEC);
else{
Serial.print(“SG “);
Serial.print(buf[0], DEC);
Serial.print(”\t”);
Serial.print(buf[1], DEC);
Serial.print(”\t\t”);
if(buf[3]>0){
printSignature(buf+4, buf[3]);
else{
Serial.println("\r\n");
/** initialize /
myVR.begin(9600);_
* Serial.begin(115200);*
* Serial.println(“Elechouse Voice Recognition V3 Module\r\nControl LED sample”);*
* pinMode(led, OUTPUT);*
* if(myVR.clear() == 0){*
* Serial.println(“Recognizer cleared.”);*
* }else{*
* Serial.println(“Not find VoiceRecognitionModule.”);*
* Serial.println(“Please check connection and restart Arduino.”);*
* while(1);*
* if(myVR.load((uint8_t)onRecord) >= 0){
_ Serial.println(“onRecord loaded”);
}*_
* if(myVR.load((uint8_t)offRecord) >= 0){
_ Serial.println(“offRecord loaded”);
int ret;
ret = myVR.recognize(buf, 50);
if(ret>0){
switch(buf[1]){
case onRecord:
/** turn on LED /
digitalWrite(led, HIGH);
* break;
case offRecord:
/** turn off LED/
* digitalWrite(led, LOW);
default:
Serial.println(“Record function undefined”);
/** voice recognized /
printVR(buf);
*_</em></em> <em><em><em>**</em></em></em> <em><em>_*
*_
