Controlling multiple PWM from serial input into arduino
Hey all,
I'm trying to send two values from max to arduino to control the brightness of two led's through the PWM outputs. I can't seem to get it to work.
Here's my arduino code:
int ledPin = 6;
int ledPin2 = 10;
int pw1 = 0;
int pw2 = 0;
Serial.begin(57600);
//data from Max
if (Serial.available() > 0 ) {
pw1 = Serial.read();
pw2 = Serial.read();
analogWrite(ledPin,pw1);
analogWrite(ledPin2,pw2);
and my max code:
----------begin_max5_patcher----------
377.3oc0T1saCBBEG+Z7ofv0NCnSsr61ywRyBprV1TnQwrt0z28An1uxZmco
sY6FQNmCvuyeNGV4APYpk7FD7A3SP.XkG.3LYM.5mCPUrk4krFWXnrVsVIQ9
ctjsUBYIW67Q1ZT0pOzZmI8GK3cGGJiImgfS6cufoymKjydtlmq6hHNI.6CI
DrcHby2MKQT3HRk85cw2ir1V64Y+3Oxbw.ZFudHWdQI0MhOc3QBMm1nSwvik
hBoF4OhLkLIJflhwXhOLhFPCM+E4CiOYNGQ1kbIqxcpnGqErx+0pAM4WHFoW
Xwf+tYaG1SMeoiMCs4uAwP74nRgmWawoKThBc8DQD6PWCxQkD5MQRZ31MDxf
woIX70u74G0mgZGRZb.kPoSLEOSNoRMxZG2RQkB4guX5.wZee0qQ0VmOP+PG
KbKAE7FsPxzBy6o6DDcuflKJJ3N+CZXknXgxHF8P.m9s2kWTlLOudSYJ8OnN
QGASo2TjN3V4JHSlIq89BvuwbKI
-----------end_max5_patcher-----------
Why won't this work?
You check that Serial.Available is greater than 0 and then you read two bytes. What if there is only one byte, which is highly likely, available?
I can't speak to the max code. I'm not able to decode whatever that block is.
