Hello,
I am newbie in Arduino. Currently i am working on project controlling multiple relays by sending SMS messages to GSM module.I designed a code and tried it on GSM module 900 it was working fine but when i tried to do same thing with GSM800 the module is not responding properly. Means module recieves SMS but unable to proceed same functions. help me and thanks in advance.
This is the code.
#include <SoftwareSerial.h>
//char inchar; //Will hold the incoming character from the Serial Port.
SoftwareSerial mySerial(4,5);
int a,b,batt,quality;
String str="";
int pin6= 6;
int pin7= 7;
char val;
int count, prev=0;
void sms()
{ digitalWrite(13,0);
Serial.println(mySerial.read());
mySerial.println("AT+CMGF=1"); //To send SMS in Text Mode
delay(2000);
mySerial.println("AT+CMGS=\"+919930275662\"\r"); // change to the phone number you using
delay(2000);
mySerial.println(str);
if(val=='@'|| val=='!'){
if(val=='@')
{mySerial.println(batt);}
else if(val='!')
{mySerial.println(quality);}}
else{mySerial.println(" ");}
delay(2000);
mySerial.println((char)26);//the stopping character
delay(5000);
mySerial.println("AT+CMGD=DEL ALL");
delay(5000);
count=0;
pinMode(13,OUTPUT);
mySerial.begin(9600);
delay(5000);
delay(3000); // give time for GSM module to register on network etc.
mySerial.println("AT+CMGF=1"); // set SMS mode to text
delay(2000);
// check();
/////////////////////////////main loop////////////////////////////////////////////////////////////////////////////
if (mySerial.available() > 0)
{ val=mySerial.read();
Serial.println(val);
switch (val)
case '@':
batt=analogRead(A0);
batt=map(batt,0,1023,0,100);
str="Battery power is good";
sms();
case '#':
digitalWrite(pin6,1); //Relay 1
delay(3000);
digitalWrite(pin6,0);
str="Power now Reset";
sms();
case '%':
digitalWrite(pin7,1); //Relay 2
delay(3000);
digitalWrite(pin7,0);
str="Internet now Reset";
sms();
case '&':
a=digitalRead(8); //AC Power check
if(a==1)
{str="AC Power Available";}
else if(a==0)
{str="AC Power Not Available";}
sms();
case '*':
b=digitalRead(9); //Internet check
if(b==1)
{str="Internet Available";}
else if(b==0)
{str="Internet Not Available";}
sms();
case '!':
quality=mySerial.println("AT+CSQ=?");
{str="Signal Quality is";}
sms();
default:
digitalWrite(13,1);
a=0;b=0;val=0;
a=digitalRead(8);
power_check();
battery();
void power_check()
if(a!=prev)
if(a==1)
{ str="Power is ON";}
else if(a==0)
{str="Power is OFF";}
sms();
prev=a;
void battery()
{ batt=analogRead(A0);
if (count==0)
if(batt<50)
{str="BATTERY LOW";sms();count=1;}
else if (batt>=50)
count=0;
