Controlling multiple servos, if loop not choosing the other servos except the first
Hi there, I'm new to this and this is my first time posting on this forum.
I'm trying to control a robotic arm that has 5 servos using the Serial Monitor input. To control the robot, I would have to give an input such as c45, where c is to choose servo C and 45 would turn the servo to its 45 degree position. Inputs with angle less than 10 and more than 170 would not be taken as it is the servos' limit.
I tested the code with input a1 and got a proper output of the angle is too low. But when I entered e45 it would move servo A to angle of 45. Any following command that chooses a servo to move to a specified angle will result in moving servo A to that specified angle. How can I rectify this?
I have not completely connected the arduino board to the robot arm as it is not ready. I am using an Arduino Uno.
Thank you in advance for taking the time to look at this.
#include <Servo.h>
#include <string.h>
Servo servoA, servoB, servoC, servoD, servoE;
int pos = 0;
const unsigned int MAX_MANUAL_INPUT=12;
  while (!Serial);
  Serial.println("-------------------------");
  Serial.println("Robo is loading....");
  Serial.println("Robo loaded succesfully");
  servoA.attach(3);
  servoB.attach(5);
  servoC.attach(6);
  servoD.attach(8);
  servoE.attach(9);
  Serial.println("calibrating servo...");  //Calibrate servos
  for (pos = 0; pos <= 180; pos += 1)      //was told it was important for debugging
  servoA.write(0);
  servoA.write(180);
  servoA.write(90);
  servoB.write(0);
  servoB.write(180);
  servoB.write(90);
  servoC.write(0);
  servoC.write(180);
  servoC.write(90);
  servoD.write(0);
  servoD.write(180);
  servoD.write(90);
  servoE.write(0);
  servoE.write(180);
  servoE.write(90);
  Serial.println("servo calibrated");
  Serial.println("Comand input online, write command to perform action");
  static char servoinput[MAX_MANUAL_INPUT];
  static char angleinput [4];
  static unsigned int input_pos = 0;
  while (Serial.available() > 0)
      char inByte = Serial.read();
      if ( inByte != '\n' && (input_pos < MAX_MANUAL_INPUT - 1) )  //store serial input
          servoinput[input_pos] = inByte;
          if ( input_pos>=1)
              angleinput[input_pos-1] = servoinput[input_pos];
          input_pos++;
          int angle = atoi(angleinput);       //change input to numbers
          Serial.println(angleinput[0]);      //Check variable contents
          Serial.println(angleinput[1]);
          Serial.println(angleinput[2]);
          Serial.println(servoinput);
          Serial.println(angle);
          static char servochoose [1];
          servochoose[0]= servoinput[0];
          Serial.println(servochoose[0]);
          servochoose[1]='\n';
          Serial.println(servochoose[1]);     //ensure servochoose doesnt have anything in [1]
          if (angle < 10)
              Serial.print(">");
              Serial.println("cannost execute command, too low number");
              servochoose[0] = '\n';
          else if (angle >= 10 && angle < 170 && strcmp(servochoose, 'a') != 0)
              Serial.print(">");
              Serial.print("turning servo A to ");
              Serial.print(angle);
              Serial.println(" degrees");
              servoA.write(angle);
              delay(30);
          else if(angle >= 10 && angle < 170 && strcmp(servochoose, 'b') != 0)
              Serial.print(">");
              Serial.print("turning servo B to ");
              servoB.write(angle);
              delay(30);
          else if(angle >= 10 && angle < 170 && strcmp(servochoose, 'c') != 0)
              Serial.print(">");
              Serial.print("turning servo C to ");
              servoC.write(angle);
              delay(30);
          else if(angle >= 10 && angle < 170 && strcmp(servochoose, 'd') != 0)
              Serial.print(">");
              Serial.print("turning servo D to ");
              servoD.write(angle);
              delay(30);
          else if(angle >= 10 && angle < 170 && strcmp(servochoose, 'e') != 0)
              Serial.print(">");
              Serial.print("turning servo E to ");
              servoE.write(angle);
              delay(30);
          input_pos = 0;      //resets all required values
          if ( servoinput != '\n' && (input_pos < MAX_MANUAL_INPUT - 1) )
              servoinput[input_pos] = '\n';
              if ( input_pos>=1)
                  angleinput[input_pos-1] = '\n';
              input_pos++;
          input_pos = 0;
this is what your for loops do because there is no {}
  for (pos = 0; pos <= 180; pos += 1)  {
    servoA.write(0);
and in the loop()
when you start having multiple instances to deal with, consider using an array
use {} to create a compound statement that will define what you want to be repeated
Strcmp compares two null terminated strings. Where you're using it, the parameters you're passing are not.
A handy thing to do is to let the IDE auto format your code (Ctrl-T) and it will adjust the indent of all the lines properly. If lines look odd, then something is wrong. For example, in your code, this happens
    servoA.write(0);
  servoA.write(180);
which shows you that only the servoA.write() statement is associated with the for() loop. The other statements are not as @J-M-L pointed out.
You also have a lot of duplicate code. Something like this should get you started...
#include <Servo.h>
const unsigned int MAX_MANUAL_INPUT = 12;
  while (!Serial);
  servoA.attach(3);
  servoB.attach(5);
  servoC.attach(6);
  servoD.attach(8);
  servoE.attach(9);
  servoA.write(0);
  servoA.write(180);
  servoA.write(90);
  servoB.write(0);
  servoB.write(180);
  servoB.write(90);
  servoC.write(0);
  servoC.write(180);
  servoC.write(90);
  servoD.write(0);
  servoD.write(180);
  servoD.write(90);
  servoE.write(0);
  servoE.write(180);
  servoE.write(90);
      input_pos++;
      servoinput[input_pos] = '\0';
      char servochoose = servoinput[0];
      int angle = atoi(&servoinput[1]);       //change input to numbers
      Serial.println(&servoinput[1]);      //Check variable contents
      Serial.println(servochoose);
      if (angle < 10)
        Serial.print(">");
        servochoose = 0;
      if (angle > 170)
        Serial.print(">");
        Serial.println("cannost execute command, too high number");
        servochoose = 0;
      if (servochoose >= 'a' && servochoose <= 'e')
        Serial.print(">");
        Serial.print("turning servo ");
        Serial.print(servochoose);
        Serial.print(" to ");
        if (servochoose == 'a')
        else if (servochoose == 'b')
        else if (servochoose == 'c')
        else if (servochoose == 'd')
        else if (servochoose == 'e')
        delay(30);
