Hello! Noob here, needing some help designing a prototype for an idea I have.
I want to create a wearable grid of vibration motors which can independently be turned off and on based on some input stream. I'm thinking I'll have somewhere in the area of 25 vibration motors.
From my very basic understanding, I'm guessing I'll need an external power supply to provide the required current for the motors (I was looking at some on amazon that required .06A each) and to power the Arduino (could this be the same power supply?). It also sounds like I'll need a transistor for each motor in order to be able to control it with the Arduino.
Apart from that, I'm not really sure where to start. I was looking at the Arduino Lilypad USB, since I'm looking for this to be a wearable circuit.
These are the vibration motors I was looking at. I'm not sure exactly what power supply or transistors I should be looking for (assuming those motors look good).
A few other questions:
Since the Lilypad only has 9 I/O pins, will I have to do some kind of demuxing to be able to control all 25 motors?
Are there transistors that are made specifically for wearables, or are they generally mounted somehow?
Are there any other components I might need for this, or any advice, tutorials, etc.?
Sorry this is kind of open-ended. I'm not really sure where to start, or what other questions to ask at this point
Higher power version of 595: TPIC6595 or TPIC6B595.
100 and 150mA continuous current outputs.
Need 3 pins: clock, serial data, output latch.
Daisy chain 4 to drive up to 32 motors.
60mA each would be fine. Be sure to put a diode across each motor to dissipate motor generated current when you switch the shift register off. (anode to drain of shift register, cathode to supply voltage. For example:
1N4148 http://www.dipmicro.com/store/1N4148
or 1N5818 http://www.dipmicro.com/store/1N5818
or 1N914B http://www.dipmicro.com/store/1N914B
Ok, so I'm trying to get everything ordered here. Are these the correct shift registers? I can't tell from the datasheet if they actually have the correct prongs for a breadboard.
I guess the only other question is what I should use for a power supply. Ideally, I'd like to have something that could be portable, but it's not necessary for the prototype.
Portable, you'll have to decide on "run time" and find appropriately capacity battery.
Maybe a big LiPo and a boost regulator, or two to split the load.
