Hi , ![]()
I have two steppers I need to test using A4988 Stepper Motor Drivers and Arduino.
STEPPERS SPECS
Nema 17 stepper motor :
200 steps per revolution (1.8 deg/step)
2 Phase bipolar 4 wires
Rated Voltage 2V DC
Rated Current 1.2A
Nema 17 stepper motor:
2 Phase 4 wires
Rated Voltage 4.83V
Rated Current 0.84A
I have connected the motors countless times according to the diagram in the link below
My circuit is powered by a 9V battery, the direction and step pins are connected to pin 8 and 9 respectively, on the Arduino. I am using a UNO board and I am quite sure that the wiring is correct unless something really important isn't mentioned on the diagram. But no matter what demo code I run, the motor just vibrates and makes a scary noise but the shaft doesn't rotate
. I really can not identify my problem, need help ![]()
