controlling of the battery charging via ESP8266
I am a student working on a project where I am required to control the battery charging via ESP8266, the idea of the project is to charge the battery with solar panel and control it via ESP8266 like charging level or when to stop charging... is there any board which I can use to connect it with ESP8266 and perform above mention task. Thanks in Advance
Your entire battery charging project must be based on the chemistry of the battery you are charging. Once you determine that, you can search the internet for the proper parameters to use while charging that particular type of battery.
Paul
Spending money buying soar cells, battories and charger, those chargers will handle the charging. Remains to measure the battory voltage, eventually the charging current and report those data. Don't invent a wheel that already exist.
@warisali13871
Other post/duplicate DELETED
Please do NOT cross post / duplicate as it wastes peoples time and efforts to have more than one post for a single topic.
Continued cross posting could result in a time out from the forum.
Could you take a few moments to Learn How To Use The Forum.
Other general help and troubleshooting advice can be found here.
