Controlling Pins via Serial
I’m teaching myself some Python and I wrote this little program that allows me to control most all of the pin functions both analog and digital on my arduino from my computer. I know this has been done a million times, but I still thought I might share.
I’d love to hear any comments. I’m sure I could have done the Arduino side a little cleaner with strtok, but it was really too easy writing this code and I probably would have had to think about strtok.
Arduino code
#define MAX_REQ_SIZE 20
#define MAX_COMMAND_SIZE 20
char req_buffer[MAX_REQ_SIZE];
int buffer_index = 0;
boolean packet_started = false;
  pinMode(17, OUTPUT);
  pinMode(18, OUTPUT);
  pinMode(19, OUTPUT);
  digitalWrite(17, HIGH);
  serialHandler();
void serialHandler()
  if (Serial.available())
    char c = Serial.read();
    if (packet_started)
      if ((c == '>') || (buffer_index == MAX_REQ_SIZE))
        req_buffer[buffer_index] = 0;
        reqHandler();
        buffer_index = 0;
        req_buffer[buffer_index] = c;
        buffer_index++;
    if (c == '<') packet_started = true;
void reqHandler()
  char* command;   // pointer to the command
  char* arg[4];    // pointers to arguments
  //char command[MAX_COMMAND_SIZE];
  command = req_buffer;  // commmand should be the first thing
  arg[0] = req_buffer;   // stert looking from beginning for the (
  while(*(arg[0]) != '(')
    (arg[0])++;
  *(arg[0]) = 0;
  (arg[0])++;   // Now arg1 points to the start of the first argument and the ( is a NULL
  boolean args_end = false;
  for(int icount = 1; icount < 4; icount++)
    arg[icount] = arg[icount - 1];  // Start scanning from the beginning of the last arg
    if(args_end) continue;     //  All the left over pointers will point to the NULL at the end.
    while(*(arg[icount])!=',')  // scan through for a comma
      if(*(arg[icount]) == ')')  // means we've hit the end
        args_end = true;
        (arg[icount])++;  // keep moving the pointer
    *(arg[icount]) = 0;  //  out of while so this is the comma, make it NULL
    if(!args_end)  //  If it's not the end, then make the pointer point to the beginning of the next argument.
      (arg[icount])++;
  //  <get(pin)>
  if(strcmp(command, "get") == 0) getCommand(arg[0]);
  //  <set(pin,state)>
  if(strcmp(command, "set") == 0) setCommand(arg[0], arg[1]);
  //  <mod(pin,mode)>
  if(strcmp(command, "mod") == 0) modCommand(arg[0], arg[1]);
  //  <all()>
  if(strcmp(command, "all") == 0) allCommand();
  //  <ana(pin)>
  if(strcmp(command, "ana") == 0) anaCommand(arg[0]);
  //  <pwm(pin,value)>
  if(strcmp(command, "pwm") == 0) pwmCommand(arg[0], arg[1]);
void anaCommand(char* pin_arg)
  int pin_number;
  int pin_value;
  pin_number = atoi(pin_arg);
  pin_value = analogRead(pin_number - 14);
  char response[30];
  sprintf(response, "<a_pin:%d:%d>", pin_number, pin_value);
  Serial.println(response);
void pwmCommand(char* pin_arg, char* val_arg)
  int pin_number;
  int pin_value;
  pin_value = atoi(val_arg);
  constrain(pin_value, 0, 255);
  analogWrite(pin_number, pin_value);
void getCommand(char* pin_arg)
  int pin_number;
  int pin_state;
  pin_state = digitalRead(pin_number);
  char response[30];
  sprintf(response, "<Pin %d:%d>", pin_number, pin_state);
void setCommand(char* pin_arg, char* state_arg)
  char state_str;
  int pin_number;
  if(*state_arg == 'h' || *state_arg =='H')
    digitalWrite(pin_number, HIGH);
    digitalWrite(pin_number, LOW);
void modCommand(char* pin_arg, char* mode_arg)
  int pin_number;
  if(*mode_arg == 'o' || *mode_arg =='O' || *mode_arg == '0')  // middle one is an oh, last one is a zero
    pinMode(pin_number, OUTPUT);
    pinMode(pin_number, INPUT);
void allCommand()
  char response[40];
  sprintf(response, "<%d:%d:%d:%d:%d:%d:%d:%d:%d>" , DDRD,PIND, PORTD, DDRB, PINB, PORTB, DDRC, PINC, PORTC);
The Python side:
# File:  Pins_7.py
import time
import threading
from Tkinter import *
import serial
ser = serial.Serial("COM4", 9600, timeout = 1)
class PinWin:
    def __init__(self, master, pin_no):
        self.myParent = master
        self.myPinNumber = pin_no
        self.analogAble = 0
        self.pwmAble = 0
        if self.myPinNumber in range(0,8):
            self.RegisterSet = 0
            self.pinOffset = 0
        elif self.myPinNumber in range(8,14):
            self.RegisterSet = 1
            self.pinOffset = 8
        elif self.myPinNumber in range(14,20):
            self.RegisterSet = 2
            self.pinOffset = 14
            self.analogAble = 1
        else:
            exit(1)
        if self.myPinNumber in [3,5,6,9,10,11]:
            self.pwmAble = 1
    ###main_frame
        self.main_frame = Frame(master, bd=1, relief = SUNKEN)
        self.main_frame.pack(side = TOP, anchor = W)
    ###widget_frames
        self.label_frame = Frame(self.main_frame, bd = 1, relief = GROOVE)
        self.in_out_frame = Frame(self.main_frame, bd = 1, relief = GROOVE)
        self.high_low_frame = Frame(self.main_frame, bd = 1, relief = GROOVE)
        self.kill_button = Button(self.main_frame, text = "X",command = self.dieGracefully)
        self.kill_button.pack(side = LEFT)
        self.label_frame.pack(side = LEFT)
        self.high_low_frame.pack(side = LEFT)
        self.in_out_frame.pack(side = LEFT)
    ###pin_label
        self.label_str = StringVar()
        self.label_str.set("Pin :  " + str(pin_no))
        self.pin_label = Label(self.label_frame, textvariable = self.label_str, relief = GROOVE)
        self.pin_label.pack(side = LEFT)
    ###state_label
        self.state_label_str = StringVar()
        self.state_label_str.set("U")
        self.mode_label_str = StringVar()
        self.mode_label_str.set("U")
        self.state_label = Label(self.label_frame, textvariable = self.state_label_str,
                                 width = 5, relief = GROOVE)
        self.state_label.pack(side = LEFT)
        self.mode_label = Label(self.label_frame, textvariable = self.mode_label_str,
        self.mode_label.pack(side = LEFT)
    ###HIGH / LOW Radio Buttons
        self.pin_val = IntVar()
        self.pin_val.set(0)
        self.radio_High = Radiobutton(self.high_low_frame, text="High", variable = self.pin_val,
                                      value = 1, command = self.setPin)
        self.radio_Low = Radiobutton(self.high_low_frame, text="Low", variable = self.pin_val,
                                      value = 0, command = self.setPin)
        self.radio_Low.pack(side = LEFT)
        self.radio_High.pack(side = LEFT)
    ###MODE Radio Buttons
        self.pin_mode = IntVar()
        self.pin_mode.set(0)
        self.radio_Output = Radiobutton(self.in_out_frame, text="Output", variable = self.pin_mode,
                                      value = 1, command = self.modPin)
        self.radio_Input = Radiobutton(self.in_out_frame, text="Input", variable = self.pin_mode,
                                      value = 0, command = self.modPin)
        self.radio_Input.pack(side = LEFT)
        self.radio_Output.pack(side = LEFT)
    ###analog_frame
        if self.analogAble == 1:
            self.analog_frame = Frame(self.main_frame, bd = 1, relief = GROOVE)
            self.analog_frame.pack(side = LEFT)
            self.analog_enable_var = IntVar()
            self.analog_enable_check = Checkbutton(self.analog_frame,
                                        text = "Analog", variable = self.analog_enable_var,
                                        command = self.analogEnable)
            self.analog_value = IntVar()
            self.analog_value.set(-1)
            self.analog_value_label = Label(self.analog_frame, textvariable = self.analog_value,
            self.analog_enable_check.pack(side = LEFT)
            self.analog_value_label.pack(side = LEFT)
    ###pwm_frame
        if self.pwmAble == 1:
            self.pwm_frame = Frame(self.main_frame, bd = 1, relief = GROOVE)
            self.pwm_frame.pack(side = LEFT)
            self.pwm_enable_var = IntVar()
            self.pwm_enable_check = Checkbutton(self.pwm_frame,
                                        text = "PWM", variable = self.pwm_enable_var,
                                        command = self.pwmEnable)
            self.pwm_value = IntVar()
            self.pwm_value.set(0)
            self.pwm_value_entry = Entry(self.pwm_frame, textvariable = self.pwm_value,
                                width = 5, relief = GROOVE, state = DISABLED)
            self.pwm_value_entry.bind("<Return>", self.pwmSet)
            self.pwm_enable_check.pack(side = LEFT)
            self.pwm_value_entry.pack(side = LEFT)
    def setPin(self):
        self.state_str = ""
        if(self.pin_val.get() == 0):
            self.state_str = "LOW"
        else:
            self.state_str = "HIGH"
        self.com_str = "<set({0!s},{1})>".format(self.myPinNumber, self.state_str)
        ser.write(self.com_str)
        if (not pins.monitor_flag) : pins.get_all()
    def modPin(self):
        self.mod_str = ""
        if(self.pin_mode.get() == 0):
            self.mod_str = "INPUT"
            self.radio_High.config(state = DISABLED)
            self.radio_Low.config(state = DISABLED)
            if self.pwmAble:
                self.pwm_enable_check.config(state = DISABLED)
        else:
            self.mod_str = "OUTPUT"
            self.radio_High.config(state = NORMAL)
            self.radio_Low.config(state = NORMAL)
            if self.pwmAble:
                self.pwm_enable_check.config(state = NORMAL)
        self.com_str = "<mod({0!s},{1})>".format(self.myPinNumber, self.mod_str)
    def analogEnable(self):
        if self.analog_enable_var.get() == 1:
            self.modPin()
            self.mod_str = "ANALOG"
            self.radio_Output.config(state = DISABLED)
            self.radio_Input.config(state = DISABLED)
            self.state_label.config(state = DISABLED)
            self.mode_label.config(state = DISABLED)
        else:
            self.radio_Output.config(state = NORMAL)
            self.radio_Input.config(state = NORMAL)
            self.state_label.config(state = NORMAL)
            self.mode_label.config(state = NORMAL)
    def pwmEnable(self):
        if self.pwm_enable_var.get() == 1:
            self.pin_mode.set(1)
            self.modPin()
            self.mod_str = "PWM"
            self.pwm_value_entry.config(state = NORMAL)
        else:
            self.pin_val.set(0)
            self.setPin()
            self.pwm_value_entry.config(state = DISABLED)
    def pwmSet(self, event):
            self.com_str = "<pwm({0!s},{1!s})>".format(self.myPinNumber, self.pwm_value_entry.get())
Python code continued:
def getFromReg(self):
        self.reg_set = pins.port_maps[self.RegisterSet]
        self._ddr = self.reg_set[0]
        self._pin = self.reg_set[1]
        self._port = self.reg_set[2]
        if((self._ddr >> (self.myPinNumber - self.pinOffset)) & 1):
            self.mode_label_str.set("OUT")
            if self.pwmAble :
            if((self._port >> (self.myPinNumber - self.pinOffset)) & 1):
                self.state_label_str.set("HIGH")
                self.pin_val.set(1)
            else:
                self.state_label_str.set("LOW")
                self.pin_val.set(0)
        else:
            self.mode_label_str.set("IN")
            if self.pwmAble:
            if((self._pin >> (self.myPinNumber - self.pinOffset)) & 1):
                self.pin_val.set(1)
            else:
                self.pin_val.set(0)
    def getAnalog(self):
        self.com_str = "<ana({0!s})>".format(self.myPinNumber)
        self.packet_finished = 0
        self.packet_started = 0
        while self.packet_finished == 0:
            ch = ser.read()
            if self.packet_started == 0:
                if ch == '<' :
                    self.packet_started = 1
                    self.resp = ""
            elif ch == '>' :
                self.packet_finished = 1
            else:
                self.resp = self.resp + ch
        self.resp_list = self.resp.split(':')
        if (self.resp_list[0] == "a_pin" and int(self.resp_list[1]) == self.myPinNumber):
            self.analog_value.set(int(self.resp_list[2]))
        else:
    def doPin(self):
                self.getAnalog()
            else:
                self.getFromReg()
        elif self.pwmAble == 1:
                pass
            else:
                self.getFromReg()
        else:
            self.getFromReg()
    def dieGracefully(self):
        self.main_frame.destroy()
        i = 0
        for pin in pins.pin_containers:
            if pin.myPinNumber == self.myPinNumber:
                pins.pin_containers.pop(i)
                break
            i=i+1
class App:
    def __init__(self, master):
    ###top_frame
        top_frame = Frame(master)
        top_frame.pack(anchor = NW, fill = BOTH, expand = YES)
    ###button_frame
        button_frame = Frame(master)
        button_frame.pack(anchor = S, fill = BOTH, expand = YES)
    ###pin_labels
        self.pin_containers = []
        for i in range(2,20):
            self.pin_containers.append(PinWin(top_frame, i))
    ###buttons
        self.button = Button(button_frame, text="QUIT", command=top_frame.quit)
        self.button.pack(side = RIGHT)
        self.hi_there = Button(button_frame, text="Say Pins", command=self.say_pins)
        self.hi_there.pack(side = RIGHT)
        self.run_button = Button(button_frame, text="Run", command=self.monitor_start)
        self.run_button.pack(side=RIGHT)
        self.monitor_flag = 0
    def reset_monitor(self):
        self.run_button.config(text = "Run", command = self.monitor_start)
    def monitor_start(self):
        self.run_button.config(text = "Stop", command = self.reset_monitor)
        self.monitor_flag = 1
        self.monitor_pins()
    def monitor_pins(self):
        self.get_all()
        if self.monitor_flag == 1:
            threading.Timer(0.5, self.monitor_pins).start()
    def say_hi(self):
        print "hi there, everyone!"
    def say_pins(self):
        self.get_all()
    def get_all(self):
        ser.write("<all()>")
            ch = ser.read()
                if ch == '<' :
                    self.resp = ""
            elif ch == '>' :
            else:
        self.port_list = self.resp.split(':')
        ###print self.port_list
        self.port_maps = [
            [int(self.port_list[0]),int(self.port_list[1]),int(self.port_list[2])],
            [int(self.port_list[3]),int(self.port_list[4]),int(self.port_list[5])],
            [int(self.port_list[6]),int(self.port_list[7]),int(self.port_list[8])]
        for pin in self.pin_containers:
            pin.doPin()
root = Tk()
pins = App(root)
root.mainloop()
Here’s a screen capture!
