Hello,
I am trying to use a stepper and a T sensor to control a window opening mechanism.
So far I have got stepper to respond by moving a set number of steps when the temperature is above or below set temperature thresholds using if statements.
The challenge now is to set a limit to the stepper motion so that it will stop turning when the window is fully closed/open... What are my options to do this?
Can I set a home position and then read the motor position relative to this and block movement beyond this point with another if statement?
should I use a limit switch?
can I set the limit the range of motion to one full rotation and then define the steps per rotation to match the range of movement that I need?
Any suggestions would be great...
My (painfully simple!) code is below.. Thanks!
#include <Stepper.h>
int in1Pin = 3;
int in2Pin = 5;
int in3Pin = 6;
int in4Pin = 9;
Stepper motor(200, in1Pin, in2Pin, in3Pin, in4Pin);
int Tpin = A1;
pinMode(in1Pin, OUTPUT);
pinMode(in2Pin, OUTPUT);
pinMode(in3Pin, OUTPUT);
pinMode(in4Pin, OUTPUT);
motor.setSpeed(30);
pinMode(Tpin, INPUT);
int reading = analogRead(Tpin);
float voltage = reading * 5.0;
voltage /= 1024.0;
float temperatureC = (voltage - 0.5)*100;
Serial.print (temperatureC); Serial.println("degrees C");
if (temperatureC >= 24) {motor.step(20);}
if (temperatureC <= 20) {motor.step(-20);}}
