Controlling RC Electronic speed controls
Hey all, I'm fairly new to the Arduino but I'm hoping to use it to control the speed of an electric motor. The motor is a brushless type and is being driven using a radio control helicopters electronic speed control. Traditionally this would plug into a servo port on a reciever and recieve its signal through the 3 wire cable plugged into the port.
Is there any way to simulate the output of a reciever to basically control the ESC? I would like to basically be able to use a rotary potentiometer to control the ESC's throttle between 0-100%.
Thanks in advance.
assuming that you have the ESC and an Arduino and downloaded the IDE forarduino (0018 or 0017).
It's just a matter of look at the examples that came with the IDE about controlling servos, signal for servos and ESC is the same
http://www.arduino.cc/playground/ComponentLib/Servo
Do NOT power the motor with the arduino as it can only support 5V and 20mA, the esc uses 17A or more at 7 to 12 volts
Are you tempting to do this?
http://quaduino.org/
David
Thanks for that. Ok this sounds fairly doable then.... famous last words!
It's actually going to be used to control the speed of the motor to maintain a preset boost pressure (it is driving the compressor side of a turbocharger).
So once I've got the basics of controlling the speed and communicating with the ESC I'll have to try and write a PID style control program.
Check out the Arduino PID library then
But you need a rotary encoder for feedback ,or else no PID :wink:
EDIT: just do a search for "PID library" in the forum
Ahh...well just do it myself Arduino Playground - GeneralCodeLibrary
David
You could get a kit like below and use your board PWM signal to drive the MOSFETs instead of the pot/chip included in the kit.
http://store.qkits.com/moreinfo.cfm/MX033
http://www.electronickits.com/kit/complete/motor/CKMX033.htm
http://www.electronickits.com/kit/complete/motor/k166.htm
@zoomkat:
He is driving a brushless motor, not ordinary dc-motor
The specs. do not indicate that it is possible to do it with those controllers
ESC van be modded to take I2C, don't think it will make it easyer tho' :wink: try it first using ppm and the servolibrary.
(straight pwm is way to fast)
http://forum.mikrokopter.com/topic-923.html
David
An electric turbocharger?
After researching such a thing on the internet (I was thinking about doing some stupid on my 4-banger Ranger), I seem to recall that they don't move enough air to make a difference on engine intake pressure (most auto forums seemed to believe they fell into the same snake oil as the "hydro boost" things - just another way to part your money).
Then again, maybe you got something different?
:slight_smile:
I did the maths on a forum years ago. I found out how much power it took to drive a mechanical supercharger and then worked out how many watts a electric version would have to consume. It was just silly.
Hey guys thanks for the replies.
FYI: basically it is being used to turbocharge a 250cc four stroke KTM engine. This means that the amount of air that needs to be pumped is quite low (finding a damn turbo that was small enough was the problem!). In terms of power required to move that air I've calculated that to maintain 7 psi of boost up to about 8000 rpm would require 1.49kW. At least that's what the sums say... :wink:
This motor is rated to 4.2kW and the speedo can push 80 amps and 50 Volts. I'll let you all know how it goes!
Cheers
Matt
