Controlling Relay with Dfrobot PH sensor Data using ESP32
My code is not working, I'm trying to use ESP32 and 5v Relay and DFRobot Ph sensor. When Ph level is at 9 and above I want my relay is high and turn it to low. This is my code.
#include <Arduino.h>
// Define the pins
const int pHpin = 36; // The GPIO pin where the pH sensor is connected
const int relayPin = 23; // The GPIO pin controlling the relay
float Offset = 0.0; // Calibration offset for pH sensor
Serial.begin(9600); // Start serial communication for debugging
pinMode(relayPin, OUTPUT); // Set the relay pin as an output
pinMode(pHpin, INPUT); // Set the pH sensor pin as an input
digitalWrite(relayPin, LOW); // Ensure the relay starts off
int pHvalue = analogRead(pHpin); // Read the analog pH value
float voltage = pHvalue * (5.0 / 4095.0); // Convert that to voltage
float pH = 3.5 * voltage + Offset; // Convert voltage to pH value
Serial.print("pH Level: ");
Serial.println(pH); // Output pH value to serial monitor
if (pH >= 9.0) {
digitalWrite(relayPin, HIGH); // Turn on the relay if pH is 9 or higher
digitalWrite(relayPin, LOW); // Turn off the relay otherwise
delay(1000); // Delay before the next reading
Hi, @jhonboyjb
Welcome to the forum.
This link will show you how to post your code.
Do you get a proper PH reading on the IDE monitor?
What do you mean by "not working"?
Please include ALL hardware, power supplies, component names and pin labels
Thanks.. Tom.. :smiley: :+1: :coffee: :australia:
