controlling relays at set times with UNO and Tiny RTC
Hi there,
i am a complete novice so bear with me.
i want to make a hydroponic system and use a relay to swtich on pumps, fans, light etc thats the plan anyway.
so far i have managed to connect a Tiny RTC and altered some code i found to switch a relay on and off at 1 certain time a day. it works great when plugged in to the computer and also stadalone so i know i have the basics right, now the thing is, would i be able to add more on and off times to this code? or is there a better way i could do it? some code some one has already done?
i am totally new to all this sort of thing. so basically all i need to do is to be able to control 4 relays at certain times of the day to switch on and off.
i used a piece of code to control an LED switching on at set times and just changed the code a bit to enable the relay. beleive me when i say that is a major thing for me ha ha!
heres the code i am using:
#include <Wire.h>
#include <RTClib.h>
RTC_DS1307 RTC;
#define RELAY1 6 // Set our relay pin
byte startHour = 10; // Set our start and end times
byte startMinute = 59; // Don't add leading zero to hour or minute - 7, not 07
byte endHour = 11; // Use 24h format for the hour, without leading zero
byte endMinute = 3;
byte validStart = 0; // Declare and set to 0 our start flag
byte poweredOn = 0; // Declare and set to 0 our current power flag
byte validEnd = 0; // Declare and set to 0 our end flag
void setup () {
pinMode(RELAY1, OUTPUT); // Set our LED as an output pin
digitalWrite(RELAY1, HIGH); // Set the LED to LOW (off)
Wire.begin(); // Start our wire and real time clock
RTC.begin();
if (! RTC.isrunning()) { // Make sure RTC is running
Serial.println("RTC is NOT running!");
//RTC.adjust(DateTime(DATE, TIME)); // Uncomment to set the date and time
void loop () {
DateTime now = RTC.now(); // Read in what our current datestamp is from RTC
if (now.second() == 0) { // Only process if we have ticked over to new minute
if (poweredOn == 0) { // Check if lights currently powered on
checkStartTime(); // If they are not, check if it's time to turn them on
checkEndTime(); // Otherwise, check if it's time to turn them off
if (validStart == 1) { // If our timer is flagged to start, turn the lights on
turnLightsOn();
if (validEnd == 1) { // If our time is flagged to end, turn the lights off
turnLightsOff();
byte checkStartTime() {
if (now.hour() == startHour && now.minute() == startMinute) {
validStart = 1; // If our start hour and minute match the current time, set 'on' flags
poweredOn = 1;
validStart = 0; // Otherwise we don't need to power up the lights yet
return validStart; // Return the status for powering up
byte checkEndTime() {
if (now.hour() == endHour && now.minute() == endMinute) {
validEnd = 1; // If our end hour and minute match the current time, set the 'off' flags
poweredOn = 0;
validEnd = 0; // Otherwise we don't need to power off the lights yet
return validEnd; // Return the status for powering off
void turnLightsOn() {
digitalWrite(RELAY1, LOW); // Turn on the relay
void turnLightsOff() {
digitalWrite(RELAY1, HIGH); // Turn off the relay
any help would be much appreciated and hopefully easy enough for me to follow, thanks in advance
rich
Have you learned about arrays of variables yet?
hi thanks, no, i must admit i have 0 programming experience. ive been programming lights to come on off etc with the digital write and delay commands, i dont think im cut out to be any sort of programmer :slight_smile:
