Controlling relays with keypad while displaying LCD info
Hello everyone!
I'm a new guy around here (although I must admit I've been lurking for a while) and new to Arduino as well. I recently took a filler course at my university on the basics of the Processing program and language which has sparked my interest in Arduino. Whenever I work on electrical projects I usually stick to analogue type stuff so I've never really been exposed to the digital side of things. I do have coding experience but this is the first time I'll need to apply it to something that matters.
Anyways, I've been requested to make a relay controller for a project and I think Arduino will definitely be the way I go from now on. I basically want to create a system using the the following components (not including the UNO):
https://www.sparkfun.com/products/8653 (Keypad - 12 Button)
http://www.ebay.com/itm/New-16-Channel-12V-Relay-Module-For-Arduino-UNO-MEGA-2560-R3-ATMEL-ATMEGA-1280-/281037857443?pt=LH_DefaultDomain_0&hash=item416f2962a3 (16-Channel 12V Relay Module)
http://www.ebay.com/itm/I2C-4-Digit-7-Seven-Segment-Display-Arduino-uController-5V-Choose-Red-or-Green-/330925449554?pt=LH_DefaultDomain_0&hash=item4d0cb1a152 (4 Digit 7 Seven Segment Display)
I'm trying to find out the most efficient way to integrate these three modules to make a relay controller. Ideally the system would run like this:
Step 1) Each relay would be assigned a number (for this case let's just say relay #1 is 01 and relay #16 is 16)
Step 2) Lets say someone wants to activate relay number 14. The person would input the digits 1 and 4 via the keypad and the numbers would show up on the display as they type.
Step 3) The person would push the * (star) key to enter the code and relay number 14 would activate.
Step 4) Let's say the person wants relay number 13 activated instead. In this case they would press the # (number) key to clear the current number and enter digits 1 and 3 via the keypad, again pushing the * (star) key to enter code activating relay number 13.
Could anyone possibly lead me in the right direction? I'm not completely clueless, so if theres any project similar to this I could reference, I could probably work off of that.
Thank you so much!
Keypad: See http://blog.arduino.cc/2010/04/08/tutorial-reading-a-12-button-keypad/ Relays: See http://arduino-info.wikispaces.com/ArduinoPower (Do you need 16?? ) Display: See http://www.arduino.cc/en/Reference/Wire
So you really need 16 relays?? Maybe 8 is simpler and all can run from 5V?? Like These?
DISCLAIMER: Mentioned stuff from my own shop...
It sounds like you're making a snack/canned drink dispensing machine. The ones where you put your money in, select which snack/drink you want by pressing the correct buttons and the requested snack/drink falls out of the bottom. Try googling for "arduino + snack dispenser" as I'm sure that someone has already done something like that.
