Controlling RGB LED's
So I'm new to controlling multiple LED's. I'm use to controlling maybe one or two for a project. I have a project that I want, that would be using 34 RGB LED's. So... where do I start, what do I read?
34 RGB leds & UNO search for shift register.
http://www.gammon.com.au/forum/?id=11518
74HC595 TPIC6B595
A couple of TLC5940NT chips daisy chained together, simple. Doesn't require a resistor for each led pin.
bluegizmo83: A couple of TLC5940NT chips daisy chained together, simple. Doesn't require a resistor for each led pin.
To be honest the 595 has a lousy source current anyway]
How easy is it to program? In lamens terms, explain how it works?
Nick Gammon explains it here: If you have questions ask.
I understand, thanks. :D
cjdelphi: To be honest the 595 has a lousy source current anyway]
that is cause its a logic chip not a driver
