I wanted to use nearly 100 RGB Leds to light at once (Like RED)and after some delay all shoulb be in different colour(like Green). I Want to use arduino. How can i do that, is there any solution to that.
Easiest with smart LEDs, buy a strip of WS2812B LEDs.
Do all leds need to be the same color or all different? That makes a HUGE difference ![]()
septillion:
It appear he wants them to be able change colors.
The example he gives is from red to green.
Yeah, but you can read that two ways ![]()
All change to the new different color but all the same.
OR all change to a individual different color.
For the first using NeoPixels is a bit overkill ![]()
septillion:
Yeah, but you can read that two waysAll change to the new different color but all the same.
OR all change to a individual different color.For the first using NeoPixels is a bit overkill
Other than RGB LEDs are there others that lets him change colors on the fly?
No, but read it again
He does not make clear of all those leds need to change to the same new color or from all being one single color to being all a different color.
All NeoPixels are RGB leds. Not all RGB leds are NeoPixels ![]()
If all those 100 (RGB) leds just need to go from red to green all at the same time NeoPixels can be used but are wayyyyyyy overkill. Normal RGB leds with simple transistors in front is way simpler and a heck of a lot cheaper.
septillion:
To me they are synonymous as when people use the brand name Kleenex to mean facial tissue.
To me they are in NO way synonymous. NoePixels and WS2801, WS2811, WS2812B, LPD8806 or TM1809 are.
But a normal RGB led
and NeoPixel
are not.
Like I said, a NeoPixel is a RGB led, a RGB led does not need to be a NeoPixel ![]()
To me, a RGB LED is a generic RGB with the controller whereas the NeoPixel is a brand name.
Then you have a weird view
To me (and many many others) a RGB led is a led and tells NOTHING about the driver. That there are leds with build in driver and we tend to call them by the brand name NeoPixel just is a subset
NeoPixel ∈ RGB led
RGB led ∉ NeoPixel
septillion:
Then you have a weird viewTo me (and many many others) a RGB led is a led and tells NOTHING about the driver. That there are leds with build in driver and we tend to call them by the brand name NeoPixel just is a subset
NeoPixel ∈ RGB led
RGB led ∉ NeoPixel
The ones I buy on eBay don't have brand names.
To me, when people are asking about them here, I translate RGB LED as being shorthand for RGB LED with controller especially when they are talking about them as on a LED strip.
If the OP doesn't mean that, then perhaps he will return and set me straight.
Then you are missing something big.
Their are four major types:-
Four connections, one positive and one for each of the grounds for R,G and B. Normally these are 12V and are controlled by a PWM signal driving a FET in each colour line. This is how you use them Usage | RGB LED Strips | Adafruit Learning System. What ever is the colour all the LEDs on that strip have the same colour.
Three connections 12V - Every three LEDs have full independent colour control.
Three connections 5V - power ground and data, of the WS2812 type sometimes called Neopixels. Each LED has full independent colour control.
Four connection 5V - power ground data clock, sometimes called dot star. Each LED has full independent colour control.
Overview | Adafruit DotStar LEDs | Adafruit Learning System
ieee488:
As Grumpy_Mike also says, I would drop that idea and ask what the person has / want to. Option 1 is still the most sold strip in China supermarkets ![]()
Grumpy_Mike:
I have never been to a supermarket in China so I don't know what they sell.
Perhaps you can point out the four types on eBay.
As I said, that's where I buy mine.
"RGB LED" to me means dumb 5/10/etc mm bulb shape with 4 leads, common anode or common cathode.
Just links to the first I could find today.
LED Strip light Tape RGB 5050 DC5V USB Cable LED Strip 1M DIY HDTV TV Dec | eBay
Ignore the controller/remote. You can easily buy them without. -
WS2811 5050 RGB LED Strip 150 300 Leds 90 60 30LED/M Individual Addressable 12V | eBay
WS2812B Strip LED Lights 5050 RGB 30/60/144 LED/M IC Individual Addressable DC5V | eBay
Adafruit DotStar Digital LED Strip White 144 LED m 1M WHITE ADA2242 | eBay
Just used the DotStar brand name but those are based on the APA102 but there are other controllers with separate clock and data.
@INTP, agreed. But on the forum I always ask just to be sure ![]()
Are you in the Netherlands? All the links are to ebay.nl
I am in the USA.
There is nothing in those auctions to indicate how #1 [5M RGB 5050 Waterproof 300 LED Strip light SMD] is different from #2 or #3. At least, #2 and #3 is differentiates by the description of WS2811 vs WS2812B
Nothing on #4 subject [Adafruit DotStar Digital LED Strip - White 144 LED/m - 1M - WHITE [ADA2242]] indicates that it is RGB, so if I searched for RGB, that auction would not show up.
All in all not a lot of in-depth information in those auctions to help me understand what is exactly different about them.
ieee488:
Yes sir I am.
ieee488:
I am in the USA.
Does not matter, all links are from international sellers in China. And they are the first I could find anyway so bad idea to blindly onder from those links
ieee488:
Yes there is, it's the fact they don't mention a controller because they have none
That's what makes them just pure RGB leds ![]()
ieee488:
What can I say? China... If all subjects / descriptions would be perfect in the far east I would not spend hours looking for stuff sometimes.
I am in the USA.
I know this might come as a shock to some in the USA but other places exist.
However you can get all the types in the USA.
Note how the pictures show the same colour on all the LEDs on the reel.
Note how their are different colours on the same reel.
Note how their are four connectors, power, data and clock.
http://led-tronix.com/product/addressable-lpd6803-30leds-5050-led-pixel-strip-lights-12v-dc-waterproof-ip67/
Note how it says "one pixel IC control three 5050 RGB"
