Controlling ROV Thursters with Arduino Mega
We are using an Arduino Mega 2560 to control four T200 BlueRobotics thrusters with ESCs. We read input from a Playstation Dual Shock controller using a separate python script, and then communicate to the Arduino via the Serial port. Our python code is here:
# operation make the controller work
import pygame
import time
import json
import pygame
import serial
import serial.tools.list_ports
servo_b_open = 60
servo_b_close = 180
servo_a_open = 60
servo_a_close = 180
# initialize serial monitor
correctdevice = str()
for port in serial.tools.list_ports.comports():
    # print(port.__dict__)
    if "arduino" in port.manufacturer.lower():
    #if "usb" in port.device.lower():
        correctdevice = port.device
print("Using serial port: ", correctdevice)
ser = serial.Serial(correctdevice, 19200, timeout=0.005)
def writeToSerial(msg):
    print("writing", msg.encode())
    ser.write(msg.encode())
def translate(value, leftMin, leftMax, rightMin, rightMax):
    # Figure out how 'wide' each range is
    leftSpan = leftMax - leftMin
    rightSpan = rightMax - rightMin
    # Convert the left range into a 0-1 range (float)
    valueScaled = float(value - leftMin) / float(leftSpan)
    # Convert the 0-1 range into a value in the right range.
    return rightMin + (valueScaled * rightSpan)
# controller testing
num = 0
pygame.init()
pygame.joystick.init()
joystick_count = pygame.joystick.get_count()
print(joystick_count)
controller = pygame.joystick.Joystick(0)
controller.init()
while True:
    for event in pygame.event.get():
        event_dict = event.dict
        if event_dict.get("axis") == 4:
            degrees = translate (event.dict.get("value"), -1, 1, servo_b_close, servo_b_open)
            print(degrees)
            writeToSerial(str(int(degrees)) + "y")
        if event_dict.get("axis") == 5:
            degrees = translate (event.dict.get("value"), -1, 1,servo_a_close, servo_a_open)
            print(degrees)
            writeToSerial(str(int(degrees)) + "x")
        if event_dict.get("axis") == 0:
            degrees = translate (event.dict.get("value"), -1, 1,1400, 1600)
            degrees = round(degrees/10)*10
            print(degrees)
            if degrees > 1490 and degrees < 1510:
                writeToSerial(str(int(1500)) + "a")
                writeToSerial(str(int(1500)) + "d")
            else:
                writeToSerial(str(int(degrees)) + "a")
                writeToSerial(str(int(degrees)) + "d")
        if event_dict.get("axis") == 1:
            c_degrees = translate (event.dict.get("value"), -1, 1,1400, 1600)
            c_degrees = round(c_degrees/10)*10
            if c_degrees > 1490 and c_degrees < 1510:
                writeToSerial(str(int(1500)) + "c")
            else:
                writeToSerial(str(int(c_degrees)) + "c")
            b_degrees = translate (event.dict.get("value"), -1, 1,1600, 1400)
            b_degrees = round(b_degrees/10)*10
            if b_degrees > 1490 and b_degrees < 1510:
                writeToSerial(str(int(1500)) + "b")
            else:
                writeToSerial(str(int(b_degrees)) + "b")
        if event_dict.get("axis")== 2 :
            a_degrees = translate (event.dict.get("value"), -1, 1,1600, 1400)
            a_degrees = round(a_degrees/10)*10
            if a_degrees > 1490 and a_degrees < 1510:
            else:
                writeToSerial(str(int(a_degrees)) + "a")
            d_degrees = translate (event.dict.get("value"), -1, 1,1400, 1600)
            d_degrees = round(d_degrees/10)*10
            if d_degrees > 1490 and d_degrees < 1510:
            else:
                writeToSerial(str(int(d_degrees)) + "d")
        if event_dict.get("axis")== 3 :
            else:
            else:
        pygame.time.wait(15)
    out = ser.readline()
    if out:
        print(out.decode(), end = '')
and our Arduino code is here:
#include <Servo.h>
#define THRUSTERS 4 // the number of Thrusters
#define STOP 1500
#define SERVOS 4 // the number of Servos
int thrusterPins[THRUSTERS] = {2, 4, 5, 3}; // Thrusters on pins 2 to 5
Servo thrusters[THRUSTERS];
int servoPins[SERVOS] = {8, 9, 11, 10}; // Servos on pins 6 to 9  (w and x are camera; y and z are claws)
Servo servos[SERVOS];
int servoPositions[SERVOS] = {10,10, 0, 0};
#define MAX_THRUSTER_STEP 5
int lastThrusterSpeeds[THRUSTERS] = {1500, 1500, 1500, 1500};
int desiredThrusterSpeeds[THRUSTERS] {1500, 1500, 1500, 1500};
#define MIN(a, b) ((a) < (b) ? (a) : (b))
#define MAX(a, b) ((a) > (b) ? (a) : (b))
  Serial.begin(19200);
  for(int i=0; i < THRUSTERS; i++)
    thrusters[i].attach(thrusterPins[i]);
    thrusters[i].writeMicroseconds(STOP);
  for(int i=0; i < SERVOS; i++)
    servos[i].attach(servoPins[i], 1000, 2000);
    servos[i].write(servoPositions[i]);
  delay(7000);
  Serial.println("Started!");
  serviceSerial();
  // Go through all the thrusters
  for(uint8_t i = 0; i < THRUSTERS; ++i)
    // Get the speed the pilot set
    int speed = desiredThrusterSpeeds[i];
    if(speed > STOP)
      // If it is in a faster forward direction, only ramp up a small step
      if(speed > lastThrusterSpeeds[i]) {
        speed = MIN(lastThrusterSpeeds[i] + MAX_THRUSTER_STEP, speed);
    } else if (speed < STOP) {
      // If it is in a faster reverse direction, only ramp up a small step
      if(speed < lastThrusterSpeeds[i]) {
        speed = MAX(lastThrusterSpeeds[i] - MAX_THRUSTER_STEP, speed);
    // If the speed we're ramping to isn't the speed the thruster is
    //  spinning at, set the thruster to the new speed.
    if(speed != lastThrusterSpeeds[i]) {
      lastThrusterSpeeds[i] = speed;
      thrusters[i].write(speed);
      Serial.print("Thruster ");
      Serial.print(i);
      Serial.print("   ramped to ");
      Serial.println(speed);
  delay(15);
void serviceSerial()
  if (Serial.available())
    int speed = Serial.parseInt();
    char ch = Serial.read();
    if (ch >= 'a' && ch < 'a' + THRUSTERS)
        char thrusterIndex = ch - 'a';
        Serial.print(thrusterIndex + 1);
        Serial.print("   set to ");
        desiredThrusterSpeeds[thrusterIndex] = speed;
   if (ch >= 'w' && ch < 'w' + 2)
        Serial.print("Servo ");
        Serial.print(ch - 'w' + 1);
        Serial.print("   add to speed ");
       int currentServoPosition = servoPositions[ch - 'w'];
       if (speed >0 && currentServoPosition + speed <= 170) {
        servoPositions[ch - 'w'] = speed + currentServoPosition;
        servos[ch - 'w'].write(servoPositions[ch - 'w'] );
        Serial.println(servoPositions[ch - 'w'] );
       else if(speed<0 && currentServoPosition + speed >= 10) {
   if (ch >= 'y' && ch < 'y' + 2) {
        servoPositions[ch - 'y' + 2] = speed;
        servos[ch - 'y' + 2].write(servoPositions[ch - 'y' + 2] );
With the current code, we should be setting speeds between 1400 and 1600. However, we are getting some output that is setting it to speeds that are negative or very large and outside that range. The thrusters are connecting and disconnecting, and have erratic behavior.
Has anyone successfully controlled their thrusters this way? Would you be willing to take a look at our code and see if you see anything problematic? Thank you!
Welcome to the forum
Please post your code
here
and
here
to avoid the need to visit an external website
Please use code tags when you post the code
done! thank you.
Thanks. See how much easier it makes it ?
What is showing up on the Serial Monitor?
Could it be that some characters are getting lost due to buffer overflow and your numbers are getting merged? Say "1400a1600b" might lose a couple of characters and become "1401600b". That would be too big to fit in a signed 16-bit integer and may get truncated to a negative number. You should probably throw away input if 'speed' is below 500 or over 2500.
