I have a need to program an Arduino to detect when a standard 125 VAC plug has power supplied to it, so that it knows when that voltage signal is present it should send a signal to a servo to move a plastic arm to a specific location. When the signal is not present, then it should return the arm to the previous pre-set position.
I've thought of using either a relay or current sensor to approach this, but need the project to be as simple as possible.
Any pointers?
cjmccorm3:
Any pointers?
Try this.
It will keep you away from direct connections to the AC supply voltages.
One of these wired to digital input is pretty doggone simple.
