Hello sir, good day! I am doing an experiment about brooding. I have dht11 sensor, lcd and servo motor. The temperature and humidity are now displayed on the LCD and the servo motor is now controlled by the dht11 sensor. I put a condition on that. Now, my problem is, if i will disconnect the connector from the computer and reconnect it, there's no display on the LCD. What might be the problem on that? Thank you.
ronzarevel,
Is this a software or hardware related question ? Do we know that yet ?
Is this something that might require reviewing your code (that you didn't post) ?
Do you think we might need to know how everything is wired ?
I'm not psychic.
I am wondering how your program knows the cable has been disconnected .
I'm assuming the whole circuit has it's own power source , right ?
Are you sending anything on the cable when your program is running ?
Is there any chance you meant to say "breeding" ?
I have a DS18B20 Temp sensor program that reads 5 sensors and displays the values on an lcd and prints values
to the serial port and if I disconnect the cable it still updates values if I power it independently .
And it doesn't recover if you press the reset button ?
I tested my lcd thermocouple program that has serial print statements and even when I disconnect the cable
it continues updating so we are probably going to need more detail to address your issue
What does that mean "I put a condition on that " ?
Please elaborate.
