I have connected up the drive to 240V and I'm getting IORDY. Both cables are connected to the motor. I have connected PULS and SIGN CN1 pins to the arduino 6 and 7, and the PULS- and SIGN- to ground. I have connected COM to E24V and I've tried connecting the DI pins to E0V. I have tried configuring P02-01 and P02-02 to all combinations of values. I used the code that was used in this video https://youtu.be/W1lqBNQX9AY. Absolutely nothing happens after the code uploads. There is extremely little information in the manual and not as good as the manual in the video. I'm obviously missing something
No sorry it won't let me upload anything because I'm not a trusted user and I can't post a link to the file because it gets removed. It was pointless creating an account to ask anything here
Yeah it's in Chinese sadly. I just Ocr translate the relevant pages but I'm going to have to translate the whole document. Tried briefly but it was too big for online converters. Any idea about anything I could be missing?
Maybe it was my comment about it being spam... my system said "do not go there" so I probably have my settings a bit tight. Maybe @PerryBebbington can undelete the link?
Thanks. I made this adjustment but still nothing. There must be some sort of additional enable that I'm missing. I do know you have to put it on P02-01: 1, Which I've done
Thanks. Arduino uno. I tried the code and it doesn't work. Starting to wonder if there's something wrong with the motor. The wires U, V, W are wired up with the correct colours and the cables are securely in the sockets. There is no sign of life from the motor. Nothing happens when I plug in the motor Power cable, but unplugging the encoder cable even if power cable is plugged in or not registers an error IEA933
Even the translated manual is not too much help. I had to translate the chinese next to the pulse and sign pins. It said "5V command pulse input (direct connection to 24V signal is prohibited)" So I assumed 5V was OK.
