I am using a Futaba S3003 Servo Motor, trying to control it without using the library. So far, I have only been able to rotate it to 45 degrees. It does not sweep to 180 degrees as the pulse length of 2ms might suggest. What am I doing wrong? Here is my code to make it turn to 180 degrees and back to 0.
Driving servos without using a library is a terrible waste of time and effort but....
Servos expect to see continuous repeating pulses. Sending a single pulse then nothing for half a second then another different length single pulse is not how they are driven.
Try sending a stream of pulses for as long as you want the servo in one position. Maybe just by using a for loop to repeat the sequence. Then you can swap to a stream with a different pulse length etc.
I hope you're not powering that big servo from the Arduino 5V pin because that might be another problem. It really needs a separate power supply. 4 x AA NiMH rechargeables would be good. Oh and the S3003 is only a 120 degree servo so don't expect to see a full 180 from it.
in other words use the Servo library. Its crazy to do anything else. However it does use timer1,
making pins 9 and 10 unavailable for analogWrite(), but there are some other libraries that use a
different timer if this is an issue.
