Hello, i want to connect 2 continuous rotational servos with 4*4 keypad, and the keypad determine the angle each servos goes to
βcould you help me with the code please?β
Yes we could. show us where you are from your own research and what questions do you face
Sure. You post the code that you have. You explain what it actually does, and how that differs from what you want, and we'll help you fix it. We won't write the code for you, though.
Iβm using this code, i want the servo go to the desired position and go back to the initial position after few seconds
the code;
#include <Keypad.h>
#include <Servo.h>
int pos = 0; // variable to store the servo position
Servo myservo; // create servo object to control a servo
const byte ROWS = 4; //four rows
const byte COLS = 4; //four columns
//define the symbols on the buttons of the keypads
char hexaKeys[ROWS][COLS] = {
{β1β,β2β,β3β,βAβ},
{β4β,β5β,β6β,βBβ},
{β7β,β8β,β9β,βCβ},
{β*β,β0β,β#β,βDβ}
byte rowPins[ROWS] = {9, 8, 7, 6}; //connect to the row pinouts of the keypad
byte colPins[COLS] = {5, 4, 3, 2}; //connect to the column pinouts of the keypad
//initialize an instance of class NewKeypad
Keypad customKeypad = Keypad( makeKeymap(hexaKeys), rowPins, colPins, ROWS, COLS);
String value = ββ;
void setup(){
myservo.attach(10); // attaches the servo on pin 9 to the servo object
void loop(){
char customKey = customKeypad.getKey(); // get the key pressed
if(customKey==β1β){ // βDβ works as βenterβ
for(pos = 0; pos < 60; pos += 1 ) // goes from 0 degrees to 180 degrees
{ // in steps of 1 degree
myservo.write(0); // tell servo to go to position in variable βposβ
delay(15); // waits 15ms for the servo to reach the position
I want the servo go to the desired position and go back to the initial position after few seconds (my project is to control to servos with keypad such as entering A and 1 will rotate the first servo by 60 degrees)
the code;
#include <Keypad.h>
#include <Servo.h>
{β1β,β2β,β3β,βAβ},
{β4β,β5β,β6β,βBβ},
{β7β,β8β,β9β,βCβ},
{β*β,β0β,β#β,βDβ}
String value = ββ;
void setup(){
void loop(){
You need to re-read Reply #2. Read it several times, if necessary. We still do not know what the code ACTUALLY does, or how that differs from what you want.
You can want it all you like but you cannot make continuous rotation "servos" go to a particular angle. The value written to such servos determines the speed and direction not the position.
Why not use conventional servos.
Welcome to the forum.
http://forum.arduino.cc/index.php/topic,148850.0.html then look down to item #7 about how to post your code.
It will be formatted in a scrolling window that makes it easier to read.
Thanks.. Tom..
