Controlling Servo with potentiometer but a very special way
Hi everybody, I'm quite new in the Arduino world and I'm deeply sorry if I do mistakes.
So here's my problem :
I want to control the angle position of a Servo motor using a potentiometer, when it is > or < at some point, I want the servo motor to run continuously in the good direction. So the potentiometer doesn't controle exactly the servo motor but a variable which increases or decreases.
For that I tried to make a first code only for the control of this variable by the potentiometer.
Also I took care of having a dead zone (between 545 and 490) for the potentiometer so when I turn back into the dead zone, it stops the variable frome increasing or decreasing.
The increase phase works, when I turn back into the Dead Zone the variable stops but if I try to decrease or increase it again, it doesn't want to continue.
What did I do wrong ?
Should I do it an other way ?
here is the code :
int val = 0; // Variable which will control the servo motor
int pot = 0; // potentiometer
  pinMode(A0, INPUT);
  pot = analogRead(A0);
  if (pot > 545) {
    if (val > 0) {
      while (!(val <= 0)) {
        if (pot > 545) {
          val = (val - 1);
          Serial.println(val);//This is to follow the count on Tinkercad serial monitor
          delay(100); // Wait for 100 millisecond(s)
  if (pot < 490) {
    if (val < 180) { //Max degree for Servomotor
      while (!(val >= 180)) {
        if (pot < 490) {
          val = (val + 1);
Sorry for my english, i'm not a native speaker and thank you for reading this
The while loops are killing you. Let the loop do the looping. Don't trap your code.
        if (pot > 545) {
          val = (val - 1);
Let's say that val is greater than 0 so you go into this while loop. Now you turn the pot back to the dead zone so you quit decreasing val. How will val ever get below 0 to end the while loop? It won't. So you're stuck there forever.
Thank you Delta_G for this fast answer.
If I understand correctly, I should remove the "While" loop and only let the "if" do their jobs ?
zerhorace:
Yes. You'll likely need another if statement to make sure that you don't increment or decrement too far though.
Delta G, I have no words to tell you how much I thank you !
Now it works fine !
Thank you very much !
