Controlling Servo with Z wave Relay + Arduino UNO
Hi
kindly help me with the circuit diagram and the code.
servo motor is connected to the relay and when the relay is switched ON the servo motor moves to 90/180 degree and when relay is turned OFF the servo motor turns back to 0 degree.
It doesn't work like that. First you make an attempt to draw a circuit diagram and the code to use it. You post them here and THEN if there are problems we help you to fix them. But first YOU put some effort in!
Steve
(deleted)
thank you sure will do.
