Controlling Servos by MPU 6050 Acc/Gyro via Wireless Medium
I am building a Project "Controlling Servos by MPU 6050 Acc/Gyro via Wireless Medium". Wireless medium for now i am using 433 MHZ RF Transmitter/ Receiver Module. I am able to establish connection bw Servos and MPU6050 through a Wired Connection but Need Help in Establishing Connection through a Wirelesss Meduim.
Need Help in Coding For the Transmitter and Receiver. I Understand only the basics of the coding and Hence could not Start the Coding.
Please Help with the Coding or Guide how to Establish Connection through a Wirelesss Meduim. Thank you
hey did you solve your problem???
I am trying to make a project where i want to control 2 servos as output, MPU 6050 (accelerometer) as an Input through a wireless medium 2.4ghz (xbee). i am not good in coding but through hit an trials i got upto this program for Transmitter side and Receiver Side. i have very little idea about the coding.
if anybody could help me in re-writing the code as to which it works perfectly would highly be appreciated.
i am trying again and again but no success…i dont want to loose hope.
Code for TX side
#include “Wire.h”
#include “I2Cdev.h”
#include “MPU6050.h”
MPU6050 mpu;
int16_t ax, ay, az;
int16_t gx, gy, gz;
int valX;
int prevValX;
int valY;
int prevValY;
Wire.begin();
Serial.begin(38400);
Serial.println(“Initialize MPU”);
mpu.initialize();
Serial.println(mpu.testConnection() ? “Connected” : “Connection failed”);
mpu.getMotion6(&ax, &ay, &az, &gx, &gy, &gz);
valX = map(ax, 750, 200, 119, 179);
valY = map(ay, 200, 700, 119, 179);
Serial.print(analogRead(valX));
Serial.print("\t");
Serial.print(analogRead(valY));
delay(200);
accelerometer values are coming from 200 to 700
Code for Receiver Side
#include “Wire.h”
#include “I2Cdev.h”
#include <Servo.h>
Servo Xservo;
Servo Yservo;
int valX;
int prevValX;
int valY;
int prevValY;
Xservo.attach(9);
Yservo.attach(10);
Xservo.write(0);
Yservo.write(0);
if(Serial.available() > 0) {
valX = Serial.read();
if (valX != prevValX)
Xservo.write(valX);
prevValX = valX;
valY = Serial.read();
if (valY != prevValY)
Yservo.write(valY);
prevValY = valY;
delay(200);
if you suggest a new coding please share…ill try that instead of this
Harkirat
