I’m looking to control the position of some servo’s using serial communication between my laptop and an arduino Mega 2560.
My code is shown below:
#include <Servo.h>
Servo serv; // define latching mechanism servo
Servo act; // define latching mechanism linear act
char incomingByte = 0;
int numBytes;
// the setup routine runs once when you press reset:
serv.attach(12);
act.attach(13);
if(Serial.available() > 0 ) { // wait for something on the serial port.
// get incoming byte:
// P - Lift latch
// L - Lower Latch
// O - Open Latch
// K - Close Latch
incomingByte = Serial.read(); // read the incoming byte
Serial.println((char)incomingByte);
if(incomingByte == 'p'){
serv.write(50);
if(incomingByte == 'l'){
serv.write(150);
if(incomingByte == 'o'){
act.write(40);
if(incomingByte == 'k'){
act.write(180);
I’m using the Arduino Serial Monitor to send the characters for commands and the Arduino is receiving the commands because the RX light is flashing, but the servo won’t move to the described positions.
At first the characters we're not showing up in the serial monitor, however, after unplugging everything and trying my set-up and code again, everything worked.
And the servo's were powered by the Arduino, they are small hobby servo's that run on 4.8v or 6v. Eventually once the project is complete I will be running off external power.
//zoomkat 11-22-12 simple delimited ',' string parse
//from serial port input (via serial monitor)
//and print result out serial port
//multi servos added
String readString;
#include <Servo.h>
Servo myservoa, myservob, myservoc, myservod; // create servo object to control a servo
//myservoa.writeMicroseconds(1500); //set initial servo position if desired
myservoa.attach(6); //the pin for the servoa control
myservob.attach(7); //the pin for the servob control
myservoc.attach(8); //the pin for the servoc control
myservod.attach(9); //the pin for the servod control
Serial.println("multi-servo-delimit-test-dual-input-11-22-12"); // so I can keep track of what is loaded
//expect single strings like 700a, or 1500c, or 2000d,
//or like 30c, or 90a, or 180d,
//or combined like 30c,180b,70a,120d,
if (Serial.available()) {
char c = Serial.read(); //gets one byte from serial buffer
if (c == ',') {
if (readString.length() >1) {
Serial.println(readString); //prints string to serial port out
int n = readString.toInt(); //convert readString into a number
// auto select appropriate value, copied from someone elses code.
if(n >= 500)
Serial.print("writing Microseconds: ");
Serial.println(n);
if(readString.indexOf('a') >0) myservoa.writeMicroseconds(n);
if(readString.indexOf('b') >0) myservob.writeMicroseconds(n);
if(readString.indexOf('c') >0) myservoc.writeMicroseconds(n);
if(readString.indexOf('d') >0) myservod.writeMicroseconds(n);
Serial.print("writing Angle: ");
Serial.println(n);
if(readString.indexOf('a') >0) myservoa.write(n);
if(readString.indexOf('b') >0) myservob.write(n);
if(readString.indexOf('c') >0) myservoc.write(n);
if(readString.indexOf('d') >0) myservod.write(n);
readString=""; //clears variable for new input
else {
readString += c; //makes the string readString
And the servo’s were powered by the Arduino, they are small hobby servo’s that run on 4.8v or 6v. Eventually once the project is complete I will be running off external power.
Were?.. not any more?- do you have external power now, do you mean?
It’s not the voltage that’s an issue, it’s the current. Even if you have no mechanical load on them, those servos could be drawing 100mA or so each, up to say 500mA if you load them… it’s risking damaging your Arduino, for sure.
As a rule of thumb, any servo “funnies” are best treated by making sure power related problems are off the table by having an external supply, even if it’s just a 4xAA pack for testing. Sometimes the problem goes away when you provide external power; if it doesn’t, well at least you’ve eliminated one possible cause.
