Controlling single stepper via blutooth
Hi All, I’m new to the wonderful world of Arduino and C++ so please be gentle with me. I have been searching the internet for days and can’t find the answer to my question.
I am wanting to control just the speed of a stepper motor via Bluetooth. I have vast experience with steppers and drivers and have it all connected up properly. Using a simple code (accellstepper lib)) I can control the speed with a 10k Pot no problem.
I have used a few bits of code that I have found online and can get the stepper to start and stop via my HC-06 Bluetooth module by issuing commands from an android terminal app.
But I am struggling to get any of the code to work using a slider built in MIT,
here is the first code that i can use with blutooth terminal on Android
#include <AccelStepper.h> // Library created by Mike McCauley at http://www.airspayce.com/mikem/arduino/AccelStepper/
// AccelStepper Setup
AccelStepper stepper(1, 8, 9);  // 1 = Easy Driver interface, Pin 4 connected to STEP pin of Easy Driver, Pin 5 connected to DIR pin of Easy Driver
#include <SoftwareSerial.h>
SoftwareSerial portOne(0, 1); // software serial #1: TX = digital pin 10, RX = digital pin 11
// Define our three input button pins
#define  button1 3
#define  button2 2
int spd = 3000;    // The current speed in steps/second
int sign = 0;      // Either 1, 0 or -1
  stepper.setMaxSpeed(3000);
  stepper.setSpeed(1000);
  // Set up the three button inputs, with pullups
  pinMode(button1, INPUT_PULLUP);
  pinMode(button2, INPUT_PULLUP);
  char c;
  if(Serial.available()) {
    c = Serial.read();
    if (c == 'f') {  // forward
      sign = 1;
    if (c == 'r') {  // reverse
      sign = -1;
    if (c == 's') {  // stop
      sign = 0;
    if (c == '1') {  // super slow
      spd = 10;
    if (c == '2') {  // slow
      spd = 100;
    if (c == '3') {  // medium
      spd = 300;
       if (c == '4') {  // fast
      spd = 500;
       if (c == '5') {  // faster
      spd = 700;
       if (c == '6') {  // superfast
      spd = 3000;
  if (digitalRead(button1) == 0) {
    sign = 1;
  else if (digitalRead(button2) == 0) {
    sign = -1;
  stepper.setSpeed(sign * spd);
  stepper.runSpeed();
This code was taken from the net. I can get it to start and stop with terminal commands but not using a slider. Any help would be muchly appreciated! Im even willing to pay for someone’s time.
Functions I want is Control Speed using slider on android and Estop button.
You are getting SoftwareSerial mixed up with Serial (HardwareSerial) in this
Serial uses pins 0 and 1. Use another pair of pins for SoftwareSerial and connect them to your Bluetooth device. Then, rather than
    c = Serial.read();
you would have
if(portone.available()) {
    c = portonel.read();
Of course you might think that portone is no longer an appropriate name for the SoftwareSerial instance.
...R
Serial Input Basics
I would never think it was. I've seen ports, and they don't look like they send or receive serial data.
OP: If you called the instance "bluetooth", don't you think it would be easier to keep the bluetooth data separate from the Serial data?
On the other hand, creating an instance of a class, SoftwareSerial in this case, but then never using the instance doesn't make a lot of sense.
