Hi. I have a pump running with a Arduino Uno+motor shield +9V battery.
I run couple of test, it works great but I would like to control the speed of the pump by adding a "regulator"> see photo attached. I tried to put it between the motor shield and the pump but it does not work..I was wondering if I need a special library to control that "regulator"...to make it work! thanks
My other idea might be to define that controlled on the analog pin, but I wonder how to deal with the 4 connector( see back picture) ( Power-, power+, Motor+, Motor-), how to define them?
Thanks!
djeh1usa:
Why not just control the speed of the pump with the motor shield?
...R
9V battery? That's something you'll need to address first.
in fact, it turns out I can control the pump directly with the motor shield, without going through Arduino. (v battery was enough to start the pump...Only pb, I can not reverse the flow direction, I only control the speed of it.
djeh1usa:
As you have not told us how you are doing that I, for one, have no idea how to help you.
...R
