controlling speed
ok I have been working with the motor shield from sparkfun and I need to control the speed of the motor by using a potentiometer this is of course not working correctly I am using a 10K pot in analog pin 0 and the motor shield is connected to pin 11 I am getting no speed from the motors I switched out the 10K and I still get nothing the motor only jitters like it wants to move but can't.
here is my code:
const int potPin = A0;
const int motorPin = 3;
int potVal = 0;
int mapedPotVal = 0;
  pinMode(potPin, INPUT);
  pinMode(motorPin, OUTPUT);
  analogWrite(motorPin, 5);
  potVal = analogRead(potPin);
  mapedPotVal = map(potVal, 0, 1023, 0, 255);
  analogWrite(motorPin, mapedPotVal);
any help would be appreciated thanks
Details would be useful
what kind of details do you want:
I have a Arduino, right now I have a 10K pot hooked up to analog pin 0 and ground, I have the Sparkfun Motor shield and the motor is connected to pin 11 and ground.
and the problem I am having is that when I toggle my pot around the motor just gitters and does not move as it should (I am trying to control motor speed through the PWM)
figured it out made a dumb mistake
thanks
made a dumb mistake
If you own up to the mistake, perhaps someone else can avoid that same mistake, and frustration, in the future.
lol no problem my error was I had no reference voltage so of course my pot wouldn't work this is why I said dumb mistake
ardlab:
Thanks!
