Hi all
I am wondering if anyone has any ideas to do the following? This is my first project working with Arduino and I need help!
I am using a 4 wire stepper motor (Nema 17 stepper motor 1.7 A).
My goal is to have a stepper be controlled by a button, I would like it so when you press the button it tells the stepper to move a certain amount of rotations.
If anyone can help that would be amazing!
Below are the parts that I currently have! Willing to purchase other parts if needed!
Parts list:
1 x CNC Shield Board
1 x Longruner UNO R3 Board
1 x 1.5m USB cable for R3 Board
3 x Nema 17 stepper motor 1.7 A (with bracket and screw)
3 x Mechanical Switch Endstop
3 x 3Pin 70cm Cable
4 x DRV8825 Stepper Motor Driver
4 x Aluminum heatsink w/ 3M tape backing
1* 400 tie-points Breadboard
1* Power Supply Module
20* Female-to-male Dupont Wire
1* 65 Jumper Wire
1* Precision Potentiometer
1* Active Buzzer
1* IC 4N35
1* Passive Buzzer
1* Thermistor
1* IC 74HC595
5* Diode Rectifier (1N4007)
5* NPN Transistor (PN2222)
2* Photoresistor
1* RGB LED
10* Button
10* White LED
10* Yellow LED
10* Blue LED
10* Green LED
10* Red LED
10* 22pf Ceramic Capacitor
10* 104 Ceramic Capacitor
10* Resistor (10R)
10* Resistor (100R)
10* Resistor (220R)
10* Resistor (330R)
10* Resistor (1K)
10* Resistor (2K)
10* Resistor (5K1)
10* Resistor (10K)
10* Resistor (100K)
10* Resistor (1M)
1* Resistance Card
2* Pin header (40pin)
5* Electrolytic Capacitor (10UF 50V)
5* Electrolytic Capacitor (100UF 50V)
