I would like to automate my blinds so that they open during the day and close during the night. The blinds are simply designed like a projector screen, so that the rod rotates clockwise to allow the fabric to go down and rotates counterclockwise to open the blinds. However, I am having trouble with the code, as the stepper motor just continuously rotates in the counter clockwise direction regardless of the value of the LDR. I would appreciate any help. Thank you.
Here is the code:
#include <Stepper.h>
int stepsPerRevolution=2048;
int ldrPin=A0;
int analogValue=0;
int prevAnalogValue=0;
Stepper myStepper(stepsPerRevolution, 8,10,9,11);
myStepper.setSpeed(10);
analogValue=analogRead(ldrPin);
if(analogValue < 50 && prevAnalogValue > 50){
myStepper.step(stepsPerRevolution*10);
else if (analogValue >= 50 && prevAnalogValue < 50){
myStepper.step(-stepsPerRevolution*10);
prevAnalogValue=analogValue;
In particular note the advice to Auto format code in the IDE and to use code tags when posting code here as it prevents some combinations of characters in code being interpreted as HTML commands such as italics, bold or a smiley character, all of which render the code useless
If the code exceeds the 9000 character inline limit then attach it to a post
What do you see if you print analogValue before testing it ?
Does the value change as you cover/expose the LDR and is it in the expected range ?
How is the LDR wired ?
Does the stepper move in the required direction if you use the commands to move it in a standalone sketch ?
How did you establish the trigger level of 50 in the first place ?
Once you have it working you may want to implement a dead band (Google hysteresis) between the open and close light levels to avoid the blinds opening and closing with a small change of light level up and down such as when a cloud passes or a car with headlight passes
An alternative would be to require the reading to stay in the trigger band for a period of time before reacting to a change
